Main Forums
Car Talk
tyre sizes
<blockquote data-quote="trex92" data-source="post: 1394722" data-attributes="member: 4353"><p>my 92% is a rough estimate from current revolution for 100m divided by previous revolution for 100m. Since the speedometer works is by mechanical cable (for proton at least). This mechanical cable would be spinning when the car is moving. This cable spinning is directly related to the wheel revolution. And for speedometer console to register speed, it might be tuned that 60 spins of the cable = 1 km. If you open up ur speedometer console, behind the meter u would see the specs for how many spins = 1 km. I forgot the actual number, think it was 67 or 87. So like i said, since the cable spinning affects the speedometer and the cable is directly related to the wheel revolution, so in theory, a % change in the number of revolution due to bigger/smaller tyre should give the same % change in the cables spinning and hence same % difference in speed reading...</p></blockquote><p></p>
[QUOTE="trex92, post: 1394722, member: 4353"] my 92% is a rough estimate from current revolution for 100m divided by previous revolution for 100m. Since the speedometer works is by mechanical cable (for proton at least). This mechanical cable would be spinning when the car is moving. This cable spinning is directly related to the wheel revolution. And for speedometer console to register speed, it might be tuned that 60 spins of the cable = 1 km. If you open up ur speedometer console, behind the meter u would see the specs for how many spins = 1 km. I forgot the actual number, think it was 67 or 87. So like i said, since the cable spinning affects the speedometer and the cable is directly related to the wheel revolution, so in theory, a % change in the number of revolution due to bigger/smaller tyre should give the same % change in the cables spinning and hence same % difference in speed reading... [/QUOTE]
R35 Used Titanium Exhaust
Main Forums
Car Talk
tyre sizes
