Car Brands
Car Manufacturers
Honda
Tyre choices.
<blockquote data-quote="shiroitenshi" data-source="post: 3156681" data-attributes="member: 27518"><p>I forgot what the name is.. rim protector? It's to prevent scratching your rim edges when you accidentally 'kerb' your car (scrape with the white and black stone block at the side of the road.)</p><p></p><p>T1R is also below RM300 at the moment for 195/55R15</p><p></p><p>Also cannot find 205/55R15.</p></blockquote><p></p>
[QUOTE="shiroitenshi, post: 3156681, member: 27518"] I forgot what the name is.. rim protector? It's to prevent scratching your rim edges when you accidentally 'kerb' your car (scrape with the white and black stone block at the side of the road.) T1R is also below RM300 at the moment for 195/55R15 Also cannot find 205/55R15. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
DIY - NVH Insulation and Tested Part 2
Hi Folks ! :wavey:
I upgraded my car rims recently from 14" to 15"
Width size? See it yourself:
(Photo courtesy of Stupidcar - those are his feet)...
(WTB) VW Golf GTI MK5 - ABS ECU
Hi,
I am looking for ABS ECU for Golf GTI 2.0l TFSI, MK5, Year 2008, Engine Code: BWA
ABS ECU (Part no. 1k0 907 379 AE) attached to ABS PUMP (Part no. 1K0 614 517 BE)
Anyone or anoybody have 1?
Sounds from the sterring
Hi all,
I noticed and heard some sounds out from my sterring whenever I trying to turn to left and right (sounds like a spring get loose like that) :confused_smile:
Do you know what is the problem? I had check the...
Car Brands
Car Manufacturers
Honda
Tyre choices.
