Main Forums
Car Talk
Car Modification
Turbo timer with no turbo :)
<blockquote data-quote="acbc" data-source="post: 1363661" data-attributes="member: 1619"><p>U must damn naughty la...</p><p></p><p>Anyway, siblings don't count unless incent la... muahahahaha!</p></blockquote><p></p>
[QUOTE="acbc, post: 1363661, member: 1619"] U must damn naughty la... Anyway, siblings don't count unless incent la... muahahahaha! [/QUOTE]
Low boost after replace TD03 turbo
Hi All sifu,
I just replace my L7 RHF3 turbo to TD03 turbo, using back the original manifold and down pipe by welding.
Turbo kicks in at ~4000rpm compare to the original RHF3 at 3000rpm.
Problem is, i just can't...
Top 10 Budget Coupe under RM30,000
Here I am again giving out the top 10 lists of vehicles you should consider for...
vr4 220hp ecu
Hi, have these question in mind:
Can this vr4 220HP ecu put into vr4 200hp?
Any advantage gain from this swap?
what is the market price for vr4 220hp ecu alone?
Thanks
Main Forums
Car Talk
Car Modification
