Main Forums
Car Talk
Forced Induction & Engine Management
Tuning with a EGT
<blockquote data-quote="Joeker" data-source="post: 1412689" data-attributes="member: 591"><p>Hybrid,</p><p></p><p>As a matter of fact, stock ECUs run alittle lean during crusing speed (for fuel economy and emission purposes)</p><p></p><p>Misfiring happens when sparks fail to arch and the Air Fule mixture is not ignited.</p><p></p><p>During knock, the ECU retards the ignition timing slightly to compensate.</p><p></p><p>However, do not confuse between knock & preignition.</p><p></p><p>Running rich at accleration & WOT also helps cool the pistons.</p><p></p><p>The general guideline will be stoich at idle, lean at cruising amd rich at WOT.</p></blockquote><p></p>
[QUOTE="Joeker, post: 1412689, member: 591"] Hybrid, As a matter of fact, stock ECUs run alittle lean during crusing speed (for fuel economy and emission purposes) Misfiring happens when sparks fail to arch and the Air Fule mixture is not ignited. During knock, the ECU retards the ignition timing slightly to compensate. However, do not confuse between knock & preignition. Running rich at accleration & WOT also helps cool the pistons. The general guideline will be stoich at idle, lean at cruising amd rich at WOT. [/QUOTE]
david tao
Basic camshaft installation guide
I've never been a believer of camshafts not because I think they're funny, only because I own an
auto
car. To make it worse - I'm...
CT9A OEM Parts
Guys,
Who has experienced changed OEM fuel filter for Evo7?.
Wanna changed mine but donno where to source. It's same with other Mitsu/Proton model?.(like oil filter, lug nuts etc).
Normally ask my mechanic to...
Autogauge oil press wiring diagram
I hope i'm not posting in the wrong forum.
Would like to enquire if there's any1 who has or can show me the wiring diagram for the autogauge oil pressure?
I just installed the sensor myself and would to try to diy...
Main Forums
Car Talk
Tuning with a EGT
