Main Forums
Interests
ICE
Tuning My System
<blockquote data-quote="Bert" data-source="post: 482147" data-attributes="member: 263"><p>RTA tunign is by analysing the frequency giving off in your car by your speakers. Best is if you have a EQ which can be used to help modify the frequency response in your car. Usually the image and level settings are first set by ear then using the RTA and EQ to set the freq response. </p><p></p><p>Reason beign is that at times if you use the x-overs and levels to set the RTA, it may not sound so good as after you get the x-over poitns and imaging as you may overstresttign the speaker to get the needed sound. Then you would need TA to get the image.</p></blockquote><p></p>
[QUOTE="Bert, post: 482147, member: 263"] RTA tunign is by analysing the frequency giving off in your car by your speakers. Best is if you have a EQ which can be used to help modify the frequency response in your car. Usually the image and level settings are first set by ear then using the RTA and EQ to set the freq response. Reason beign is that at times if you use the x-overs and levels to set the RTA, it may not sound so good as after you get the x-over poitns and imaging as you may overstresttign the speaker to get the needed sound. Then you would need TA to get the image. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
BTCC Champion and Fifth Gear host Jason Plato takes the Ferrari 599 GTO for a spin
https://www.zerotohundred.com/wp-content/uploads/2010/07/Jason-Plato-Ferrari-599-GTO.jpg
Video reviews are all the rave these days, of course this trend was started off by the merry men at Top Gear but sometimes...
Evo 456 arm rest and CK complete seat_fr & rr)
moderator plz delete.....thanks
TwinCharger..any idea?
it is possible that we use twincharger just like in a nissan march?
a 20v 4AGZTE is a good base?
Main Forums
Interests
ICE
Tuning My System
