Car Brands
Car Manufacturers
Toyota
Toyota Le izzit a nice car?
<blockquote data-quote="Acoustic" data-source="post: 386137" data-attributes="member: 728"><p>I forced my elder sister to buy a LE after test driving sifu master pendekar GT20v @ zul's LE.</p><p></p><p>Now she enjoys installment-free :)</p><p></p><p>But her car got chassis breaking problem. LE very old already, allot of weld loose. Unlike sifu zul's LE :(</p><p></p><p>So, we'll need to send the car in for chassis repair. </p><p></p><p>So, if you buy LE, make sure to check chassis. If chassis no good then make sure to repair it after find it.</p><p></p><p>I won't say if chassis no good then don't buy because I think cannot find.</p><p></p><p>If found sure expensive. So I rather buy and repair because repair bill normally cheaper than expensive LE.</p><p></p><p>When I test drive my sister's car before purchase I already knew, just didn't want to think too much. After buy and test more confirm no good. So start to look around repair shop. Cost is reasonable for repair.</p><p></p><p>total cost is much much cheaper than buy the so-called good condition chassis, which may break when you buy it. Cause most likely you'll put in sports suspension and old chassis will break quickly.</p></blockquote><p></p>
[QUOTE="Acoustic, post: 386137, member: 728"] I forced my elder sister to buy a LE after test driving sifu master pendekar GT20v @ zul's LE. Now she enjoys installment-free :) But her car got chassis breaking problem. LE very old already, allot of weld loose. Unlike sifu zul's LE :( So, we'll need to send the car in for chassis repair. So, if you buy LE, make sure to check chassis. If chassis no good then make sure to repair it after find it. I won't say if chassis no good then don't buy because I think cannot find. If found sure expensive. So I rather buy and repair because repair bill normally cheaper than expensive LE. When I test drive my sister's car before purchase I already knew, just didn't want to think too much. After buy and test more confirm no good. So start to look around repair shop. Cost is reasonable for repair. total cost is much much cheaper than buy the so-called good condition chassis, which may break when you buy it. Cause most likely you'll put in sports suspension and old chassis will break quickly. [/QUOTE]
david tao
Stock absorber !!
Is there any good guy willing to borrow his stock absorber to test? I'm having a problem that the front left side has got a sound " katak katak"when I hit a hump and bumpy road~ I've changed lower arm bush but same~...
ver 8 sti
guys, newbie here ..just bought a scooby ver 8..
is it worth convert to ver 9 n much is d cost ? just no budget to buy ver 9,sti lo.
thanks in advance guys
Myth on Z killer ?
There's alot of rumour about a Z killer.. aka TO4Z.. but the true fact is they are comparing against a old skool spec..obviously they forgot...
anyway..many have not known the successor to T04Z..which is similar but...
Car Brands
Car Manufacturers
Toyota
