car was manufactured in 1987.
front moded to supra Mk3 facelift, rear 6-7cm wider each side with ae86 rear lamp.
2 frameless door. painted with flat blackall over the body, internal and external.
including underbody. fully anti-rust work done. i would say 1-5% rust all around.
engine
1jz supra mk3 manual engine.
comes with,
-hks ball bearing twin turbo, equip with stainless steel hoses. no shaft play from the turbo shaft.
-HKS spark plug
-new timing belt set
-replaced all new gasket, jus only the head gasket remains.
- rear oil-sump pan.
-60-70% life-span left for the mounting.
-most of the part was dismantled out for cleaning purpose.( inlet manifold, water pump, aircond compressor, power steering pump, removed all dirt from the engine and etc.
-all AUX parts are screwed and located at the proper place (no hanging stuff or cable tied.
-4" Original TRD full set exhaust sys, 80%new.
-Computer box with CHIPS.
parts
-skyline r32 brake servo
-stainless steel brake hoses
-jic magic front absorber from toyota mk2
-trd rear absorber
-trd 80% new full exhaust system
-hks cast iron (oversized) exhaust manifold.
-standard intercooler
-extremely spot-welded in the engine bay.
- new timing belt
-r154 manual gear box
-supra patrol pump, and tank.
-SARD SQV.
-Mark 2 converted dashboard.
-fully spot welded.
front extra spot welded, lowered engine, all painted removed and applied new anti rust paint for primary and secondary. all fully custom made metal wide body , not fibre.
the locks for the doors and rebuild, and sounds like new doors.
new timing belt, and new head gasket. new 7 litre racing oil.
freebie
-standard twin turbo
-toyota auto start remote system
-carbon fibre gear knob
-alot more.
spend more than 30k
im selling it 4 only rm16000
engine
comes with,
-HKS spark plug
parts
-trd rear absorber
- new timing belt
-SARD SQV.
-fully spot welded.
freebie
-alot more.
spend more than 30k
