Main Forums
Car Talk
Car Modification
thermostat
<blockquote data-quote="praetorian" data-source="post: 1482153" data-attributes="member: 3094"><p>guys,</p><p>i think that running without thermostat will cause ur engine to run cold.you may also end up using more fuel. the thermostat will open at a specific temp only, if the car is running hot, you may have other probs.</p><p>jes me 2sen worth:)</p></blockquote><p></p>
[QUOTE="praetorian, post: 1482153, member: 3094"] guys, i think that running without thermostat will cause ur engine to run cold.you may also end up using more fuel. the thermostat will open at a specific temp only, if the car is running hot, you may have other probs. jes me 2sen worth:) [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
OmniTicket to provide ticketing solutions for Singapore F1 Grand Prix
OmniTicket Network to Provide Comprehensive Ticketing Solution for 2008 Formula 1™ Singapore Grand Prix
Singapore, 11 October, 2007 - OmniTicket Network, a leading provider of admission...
have you seen an S13 (Silvia/180SX) rear cut?
Hi guys,
Seen an S13 (Silvia or 180SX) rear cut around? I need some parts from there.
If you have seen one... please reply to me.
Thanks in advance!
regards,
S13-GTS
need advise on GSR
me running on 0.8bar...lately for the past week or so..my car cannot 'go' like it used to...when i whack the throttle, as the rpm climbs, the car will jerk or semput when it reaches say abt 4-5k rpm...was running...
Main Forums
Car Talk
Car Modification
thermostat
