Car Brands
Car Manufacturers
The Bmw Engine Lists, Specs And Faqs
<blockquote data-quote="Tom" data-source="post: 32296"><p>By:</p><p>Chapel</p><p><a href="http://www.mwerks.com" target="_blank">www.mwerks.com</a></p><p></p><p></p><p>Horsepower quotes may not always reflect US Rating</p><p>If there are two HP numbers, lower HP number generally denotes US rating</p><p></p><p>M10 - Straight 4 cylinder SOHC 8V. 1966-1987. 83kg 180lbs</p><p>Used in 1502, 1600-2, E21 316/318i/320-4, E30 316, 2002tii and 2002 turbo</p><p>1.5 (75bhp), 1.6 (85bhp), 1.8 (90-98bhp), 2.0 (100bhp), 2.0i (125bhp), 2.0tii (130bhp), 2.0turbo (170bhp)</p><p></p><p>M20 - Straight 6 cylinder SOHC 12V. Baby Six. 1977-1992. 117kg 258lbs</p><p>Used in E21 320, E21 320i/6, E28, E30, E34, E21/30 323i, E30 325e and E28 528e</p><p>2.0i (129bhp), 2.3i (143bhp), 2.5i (170bhp), 2.7e (125bhp)</p><p></p><p>M30 - Straight 6 cylinder SOHC 12V. Big Six. 1973-1993. 143kg 315lbs</p><p>Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535</p><p>2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp)</p><p></p><p>M102 - Straight 6 cylinder SOHC 12V Turbo. Big Six Turbo. 1984-1986. 145kg 320lbs.</p><p>Used only in the E23 745i</p><p>3.2L or 3.4L Turbo (252bhp)</p><p></p><p>M40 - Straight 4 cylinder SOHC 8V. Replaced the M10. 1987-1993. 81kg 178lbs</p><p>Used in post 87 E30 316i/318i, E34 518i, Pre 93 E36 316i</p><p>1.6 (102bhp), 1.8 (122bhp)</p><p></p><p>M42 - Straight 4 cylinder DOHC 16V. 1989-1996. 100kg 220lbs</p><p>Used in E30 and E36 318is, Z3</p><p>1.8 (138-142bhp)</p><p></p><p>M43 - Straight 4 SOHC 8V. 1993-1998. 83kg 183lbs</p><p>Used in post-93 E36 316i/318i, E34/39 518i.</p><p>1.6 (102bhp), 1.8 (115bhp)</p><p></p><p>M43TU - Straight 4 SOHC 8V. 1998 on. 83kg 183lbs</p><p>Used in E46 318i</p><p>1.9 (118bhp)</p><p></p><p>M44 - Straight 4 DOHC 16V. 1996 on. 102kg 225lbs</p><p>Used in E36 318iS, Z3</p><p>1.9 (142-150bhp)</p><p></p><p>M50/M50TU - Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs</p><p>Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3</p><p>2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) Sometimes referred to as S50US. Engine shares more common parts with M50 than Euro S50, but is a motorsport engine.</p><p></p><p>M52/M52TU - Straight 6 DOHC 24V with Single VANOS/Straight 6 DOHC 24V with Double VANOS. 1996-1999. Iron Block in US, Alloy Block in Europe. 118kg 260lbs (alloy) 140kg 308lbs</p><p>Used in E39 520i/523i/528i, E36 323i/328i, E38 728i, Variation of this was used in late US E36 M3.</p><p>2.0 (150bhp), 2.5 (170bhp), 2.8 (193bhp), 3.2 (240bhp) Sometimes referred to as S52US. Engine shares more common parts with M52 than Euro S50, but is a motorsport engine.</p><p></p><p>M54 - Straight 6 DOHC 24V with Dual VANOS. 2000-present. 126kg 277lbs</p><p>Used in late model Z3, all E39 and E46 six cylinder models</p><p>2.0 (150bhp), 2.2 (170bhp), 2.5 (184-192bhp), 2.8 (193bhp), 3.0 (231bhp)</p><p></p><p>M56 - Straight 6 DOHC 24V Dual VANOS with ULEV. 2002-present. 127kg 280lbs</p><p>Used in some E39 and E46 six cylinder models</p><p>2.5 (184bhp)</p><p></p><p>M60 - V8 DOHC 32V. 1992-1996. 146kg 321lbs</p><p>Engine blocks were made of Nikasil (Silicone Injected Nickel) which were prone to failure over time. Many have been replaced with the newer Alusil (Silicone injected Aluminum) engines/</p><p>Used in E34 530i, E32 730i, 740i, 840i</p><p>3.0 (218bhp), 4.0 (286bhp)</p><p></p><p>M62/M62TU - V8 DOHC 32V/V8 DOHC 32V Single VANOS. 1996-present. Alusil Engine block. Pre 98 engines were non-VANOS. 140kg 308lbs</p><p>Used in E38 730i/740i, E39 540i, X5 and 840i</p><p>3.5 (235bhp), 4.4L (286bhp), 4.6 (340bhp)</p><p></p><p>M70 - V12 SOHC 24V. 1988-1994. 155kg 341lbs</p><p>Used in E32 750il, 850i</p><p>5.0 (300bhp)</p><p></p><p>M73 - V12 SOHC 24V Single VANOS. 1995-2001. Pre 98 engines were non-VANOS. 150kg 330lbs</p><p>5.4L (326bhp)</p><p></p><p>http://www.unixnerd.demon.co.uk/s14.jpg</p><p>S14 - Straight 4 DOHC 16V Solid Lifter Valvetrain and Individual Throttle Bodies. 1987-1991. 106kg 234lbs</p><p>Used in the E30 M3 and Italian only E30 320is</p><p>2.0L (195bhp) 2.3L (192-200bhp), 2.5L (215-238bhp)</p><p></p><p>http://www.unixnerd.demon.co.uk/s38m1.jpg</p><p>Original S38 (Also known as M88 and M88/3)- Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1979-1980, 1986-1990. 146kg 321lbs</p><p>Used in M1, E28 M5, M6, SA E23 745i</p><p>3.5L (277-286bhp)</p><p></p><p>http://www.unixnerd.demon.co.uk/s38.jpg</p><p>Updated S38 - Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1988-1996. 151kg 332lbs</p><p>Used in E34 M5</p><p>3.6 (315bhp), 3.8 (340bhp)</p><p></p><p>http://www.ne.jp/asahi/kitaho2/bmw-m3smg/e36engine-s50-01s1-00.jpg</p><p>S50 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies. (Dual Vanos on 3.2Ls) 1992-2000. 152kg 333lbs</p><p>Used in non-US E36 M3</p><p>3.0 (286bhp), 3.2L (321bhp)</p><p></p><p>http://undergrad.nova.edu/kevin/s54-EngineWhole.jpg</p><p>S54 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 2001-present. 148kg 326lbs</p><p>Used in the E46 M3 and the last of the Z3 M-Coupe and M-Roadster.</p><p>3.2 (321-343bhp)</p><p></p><p>http://www.unixnerd.demon.co.uk/s62.jpg</p><p>S62 - V8 DOHC 32V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 1999-present. 158kg 348lbs</p><p>Used in E39 M5 and Z8</p><p>4.9L (400bhp)</p><p></p><p>S70 - V12 SOHC 24V. 1995-1997. 165kg 363lbs</p><p>Used in 850CSi</p><p>5.6L (380bhp)</p><p></p><p>http://autozine.kyul.net/classic/mclaren/f1_eng.jpg</p><p>S70/2 - V12 DOHC 48V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies</p><p>Used in McLaren F1 (Was originally developed for M8)</p><p>6.1 (627bhp)</p><p></p><p>M21 - straight 6 SOHC 12V Diesel. 1983-1991 126kg 278lbs</p><p>Used in 324td, 524d/td</p><p>2.4 (112bhp), 2.4 Turbo (115bhp)</p><p></p><p>M41 - Straight 4 SOHC 8V Diesel. 1995-on. 108kg 238lbs</p><p>Used in E36 318tdS</p><p>1.7 Turbo (90bhp)</p><p></p><p>M51 - Straight 6 SOHC 12V Diesel. 1995-on. 132kg 291lbs</p><p>Used in E36 325td/S, E34 and E39</p><p>2.5 Turbo (115bhp), 2.5 Intercooled Turbo (143bhp)</p><p></p><p>M47 - Straight 4 DOHC 16V Diesel. 1998-on. 117kg 258lbs</p><p>Used in E46 320d</p><p>2.0 Turbo (136bhp)</p><p></p><p>M55 - Straight 6 DOHC 24V Diesel. 2000-on. 132kg 291lbs</p><p>Used in E46 and E39s.</p><p>2.5 Turbo (170bhp), 3.0 Turbo (183bhp)</p><p></p><p>M67 - V8 DOHC 32V Diesel. 1999-on. 192kg 423lbs</p><p>Used in E38 740d</p><p>4.0 Turbo (245bhp)</p><p></p><p>N44TU - Straight 4 DOHC 16V Dual VANOS with Valvetronic</p><p>Used in E46 318i</p><p>1.6 (115bhp), 1.8 (143bhp)</p><p></p><p>N62 - V8 DOHC 32V Dual VANOS with Valvetronic</p><p>Used in E65 745i</p><p>4.4 (325bhp)</p><p></p><p>N73 - V12 DOHC 48V Dual VANOS with Valvetronic</p><p>Used in E65 760i </p><p>6.0 (438bhp)</p><p></p><p>http://www.bmwworld.com/pics/mini/4981_832.jpg</p><p>W10 - Straight 4 SOHC 16V </p><p>Used in Mini One, Mini Cooper</p><p>1.6 (90-115bhp)</p><p></p><p>[ATTACH=full]591065[/ATTACH]</p><p>W11 - Straight 4 SOHC 16V with Eaton Supercharger</p><p>Used in Mini Cooper S</p><p>1.6 Supercharged (163bhp)</</p></blockquote><p></p>
[QUOTE="Tom, post: 32296"] By: Chapel [url]www.mwerks.com[/url] Horsepower quotes may not always reflect US Rating If there are two HP numbers, lower HP number generally denotes US rating M10 - Straight 4 cylinder SOHC 8V. 1966-1987. 83kg 180lbs Used in 1502, 1600-2, E21 316/318i/320-4, E30 316, 2002tii and 2002 turbo 1.5 (75bhp), 1.6 (85bhp), 1.8 (90-98bhp), 2.0 (100bhp), 2.0i (125bhp), 2.0tii (130bhp), 2.0turbo (170bhp) M20 - Straight 6 cylinder SOHC 12V. Baby Six. 1977-1992. 117kg 258lbs Used in E21 320, E21 320i/6, E28, E30, E34, E21/30 323i, E30 325e and E28 528e 2.0i (129bhp), 2.3i (143bhp), 2.5i (170bhp), 2.7e (125bhp) M30 - Straight 6 cylinder SOHC 12V. Big Six. 1973-1993. 143kg 315lbs Used in E12 525/528, E28 525i, E23 725i, 2800CS, E28 528i, E23 728i, 3.0CS/i/L, 3.0Si, E12 530i, E23 730i, 3.3Li, 633, 732i, 733i, 535i, 635i, 735i, E12 M535 2.5i (150bhp), 2.8i (184bhp), 3.0 (185-208bhp), 3.3 (200-206bhp), 3.5 (218bhp) M102 - Straight 6 cylinder SOHC 12V Turbo. Big Six Turbo. 1984-1986. 145kg 320lbs. Used only in the E23 745i 3.2L or 3.4L Turbo (252bhp) M40 - Straight 4 cylinder SOHC 8V. Replaced the M10. 1987-1993. 81kg 178lbs Used in post 87 E30 316i/318i, E34 518i, Pre 93 E36 316i 1.6 (102bhp), 1.8 (122bhp) M42 - Straight 4 cylinder DOHC 16V. 1989-1996. 100kg 220lbs Used in E30 and E36 318is, Z3 1.8 (138-142bhp) M43 - Straight 4 SOHC 8V. 1993-1998. 83kg 183lbs Used in post-93 E36 316i/318i, E34/39 518i. 1.6 (102bhp), 1.8 (115bhp) M43TU - Straight 4 SOHC 8V. 1998 on. 83kg 183lbs Used in E46 318i 1.9 (118bhp) M44 - Straight 4 DOHC 16V. 1996 on. 102kg 225lbs Used in E36 318iS, Z3 1.9 (142-150bhp) M50/M50TU - Straight 6 DOHC 24V/Straight 6 DOHC 24V with Single VANOS. 1989-1998. 136kg 299lbs Used in E36 320i/325i, E34/39 520i/525i, Variation of this was used in the Early US E36 M3 2.0 (150bhp), 2.5 (192bhp), 3.0 (240bhp) Sometimes referred to as S50US. Engine shares more common parts with M50 than Euro S50, but is a motorsport engine. M52/M52TU - Straight 6 DOHC 24V with Single VANOS/Straight 6 DOHC 24V with Double VANOS. 1996-1999. Iron Block in US, Alloy Block in Europe. 118kg 260lbs (alloy) 140kg 308lbs Used in E39 520i/523i/528i, E36 323i/328i, E38 728i, Variation of this was used in late US E36 M3. 2.0 (150bhp), 2.5 (170bhp), 2.8 (193bhp), 3.2 (240bhp) Sometimes referred to as S52US. Engine shares more common parts with M52 than Euro S50, but is a motorsport engine. M54 - Straight 6 DOHC 24V with Dual VANOS. 2000-present. 126kg 277lbs Used in late model Z3, all E39 and E46 six cylinder models 2.0 (150bhp), 2.2 (170bhp), 2.5 (184-192bhp), 2.8 (193bhp), 3.0 (231bhp) M56 - Straight 6 DOHC 24V Dual VANOS with ULEV. 2002-present. 127kg 280lbs Used in some E39 and E46 six cylinder models 2.5 (184bhp) M60 - V8 DOHC 32V. 1992-1996. 146kg 321lbs Engine blocks were made of Nikasil (Silicone Injected Nickel) which were prone to failure over time. Many have been replaced with the newer Alusil (Silicone injected Aluminum) engines/ Used in E34 530i, E32 730i, 740i, 840i 3.0 (218bhp), 4.0 (286bhp) M62/M62TU - V8 DOHC 32V/V8 DOHC 32V Single VANOS. 1996-present. Alusil Engine block. Pre 98 engines were non-VANOS. 140kg 308lbs Used in E38 730i/740i, E39 540i, X5 and 840i 3.5 (235bhp), 4.4L (286bhp), 4.6 (340bhp) M70 - V12 SOHC 24V. 1988-1994. 155kg 341lbs Used in E32 750il, 850i 5.0 (300bhp) M73 - V12 SOHC 24V Single VANOS. 1995-2001. Pre 98 engines were non-VANOS. 150kg 330lbs 5.4L (326bhp) http://www.unixnerd.demon.co.uk/s14.jpg S14 - Straight 4 DOHC 16V Solid Lifter Valvetrain and Individual Throttle Bodies. 1987-1991. 106kg 234lbs Used in the E30 M3 and Italian only E30 320is 2.0L (195bhp) 2.3L (192-200bhp), 2.5L (215-238bhp) http://www.unixnerd.demon.co.uk/s38m1.jpg Original S38 (Also known as M88 and M88/3)- Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1979-1980, 1986-1990. 146kg 321lbs Used in M1, E28 M5, M6, SA E23 745i 3.5L (277-286bhp) http://www.unixnerd.demon.co.uk/s38.jpg Updated S38 - Straight 6 DOHC 24V Solid Lifter Valvetrain and Individual Throttle Bodies. 1988-1996. 151kg 332lbs Used in E34 M5 3.6 (315bhp), 3.8 (340bhp) http://www.ne.jp/asahi/kitaho2/bmw-m3smg/e36engine-s50-01s1-00.jpg S50 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies. (Dual Vanos on 3.2Ls) 1992-2000. 152kg 333lbs Used in non-US E36 M3 3.0 (286bhp), 3.2L (321bhp) http://undergrad.nova.edu/kevin/s54-EngineWhole.jpg S54 - Straight 6 DOHC 24V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 2001-present. 148kg 326lbs Used in the E46 M3 and the last of the Z3 M-Coupe and M-Roadster. 3.2 (321-343bhp) http://www.unixnerd.demon.co.uk/s62.jpg S62 - V8 DOHC 32V Solid Lifter Valvetrain with Dual VANOS and Individual Throttle Bodies. 1999-present. 158kg 348lbs Used in E39 M5 and Z8 4.9L (400bhp) S70 - V12 SOHC 24V. 1995-1997. 165kg 363lbs Used in 850CSi 5.6L (380bhp) http://autozine.kyul.net/classic/mclaren/f1_eng.jpg S70/2 - V12 DOHC 48V Solid Lifter Valvetrain with Single VANOS and Individual Throttle Bodies Used in McLaren F1 (Was originally developed for M8) 6.1 (627bhp) M21 - straight 6 SOHC 12V Diesel. 1983-1991 126kg 278lbs Used in 324td, 524d/td 2.4 (112bhp), 2.4 Turbo (115bhp) M41 - Straight 4 SOHC 8V Diesel. 1995-on. 108kg 238lbs Used in E36 318tdS 1.7 Turbo (90bhp) M51 - Straight 6 SOHC 12V Diesel. 1995-on. 132kg 291lbs Used in E36 325td/S, E34 and E39 2.5 Turbo (115bhp), 2.5 Intercooled Turbo (143bhp) M47 - Straight 4 DOHC 16V Diesel. 1998-on. 117kg 258lbs Used in E46 320d 2.0 Turbo (136bhp) M55 - Straight 6 DOHC 24V Diesel. 2000-on. 132kg 291lbs Used in E46 and E39s. 2.5 Turbo (170bhp), 3.0 Turbo (183bhp) M67 - V8 DOHC 32V Diesel. 1999-on. 192kg 423lbs Used in E38 740d 4.0 Turbo (245bhp) N44TU - Straight 4 DOHC 16V Dual VANOS with Valvetronic Used in E46 318i 1.6 (115bhp), 1.8 (143bhp) N62 - V8 DOHC 32V Dual VANOS with Valvetronic Used in E65 745i 4.4 (325bhp) N73 - V12 DOHC 48V Dual VANOS with Valvetronic Used in E65 760i 6.0 (438bhp) http://www.bmwworld.com/pics/mini/4981_832.jpg W10 - Straight 4 SOHC 16V Used in Mini One, Mini Cooper 1.6 (90-115bhp) [ATTACH=full]591065[/ATTACH] W11 - Straight 4 SOHC 16V with Eaton Supercharger Used in Mini Cooper S 1.6 Supercharged (163bhp)</ [/QUOTE]
Wiring for door lock
Please help me wiring for door lock.If press the brake,door lock.
My car WIRA AUTO and the alarm system is original wira alarm.Please help meee...
:confused_smile:
brandnew bumper 4 bncr33
bumper bncr33 new 4 sell $1700rm
Looking for 1.8 Gdi Turbo power steering pump.
Please call/sms 012-354 7181. Am in PJ.
Car Brands
Car Manufacturers
