The best voltage stabilizer in offer now !!
ICE -In Car Entertainment
PowerMotion
I am promotiong this industrial use capacitor that can store up to 35000uf of electric current for your car electrical system to prevent electrical surge that happen while your car electronic components start, load and off. It act as a reservoir to your electrical system that reserve current and stabilize the current flow by reducing current surge while your equipment suddenly draws current or stop functioning.
This capacitor were widely used in auto transformer and step down transformer that we used in major car audio competition and high quality battery chargers. Cornell Dubilier were an established company that specialized in capacitors and electrical control system. Thus, this product are giving enough confidence to end user that can help to reduce the load of your battery and alternators. Even save fuels !!!
Main functions:
1. Reduce surge speed
2. Reduce current surge level
3. Increase supplied current speed
4. Increase voltage stability
5. Increase electronic component's performance like radio, air-cond, headlight, sensors, and ECU
6. Save fuel if your current system are lack of current reservoir
7. Increase engine response by more accurate ECU and sensors readings.
This component is easy to setup and it's far more cheaper than any capacitor that used in most of the VS selling in the market compared to their price vs performance ratio. We had use it in SG for extreme Car audio competition like IASCA and SEMA, not to mention we even use it on our battery operated remote car to provide more responsive and stable voltage and our PC overclock competition to reduce the chances of failure from pc power supply.
For more enquiries, pls do call me at 016-3634000.
COD can be done in sri petaling / bukit jalil area. Other places free shipping.
RM65 each.
Connection diagram will be up soon. Just install it on your battery terminal or near your car audio amplifier connectors for best result in car audio. It act exactly like Helix baby cap.
yes can. not a big prob to me. but dun make me sweating when installing ya..
bro, you said it is 35000uF.
but the markings on the unit itself is indicating it as 22000uF.
free bump too :D
i think TS typing error... its stated on the cap itself its 22,000uF
This cap is the highest i can found. Higher 1 already become oem for other ice brand babycap so not selling in market seperately..so this is highest capacity we got in malaysia as babycap.
the rated is 22000uf on the cap. but dun forget the tolerance is -10% and +50%. if you guys were install it in a well place with lower temp, it can actually store up to 20-30% more than rated capacity. like how branded amplifier rate their amps. since i had install quite a few type of vs before, i can tell u this vs really worth the money because i really feel the surge when my aircond kick in were greatly reduced and my hu dimming prob were near 100% eliminated.
where to apply? on the battery or on the alternator?
normally on battery terminal for easier access. if your alternator can be access easily, you can install near it too.
Bump: keep my post up
