Car Clubs
Car Club Categories
Mitsubishi Lancer Owners Club
Terrible knocking problem, help!
<blockquote data-quote="dawg" data-source="post: 4217638" data-attributes="member: 839"><p>I'm assuming the chatter sound maybe be from the tensioner instead of knocking. If your A/F ratio is 11-12 you are on the rich side. Stoich is 14.7 and lean would be above 14.7 ...</p><p></p><p>Evos tend to have this problem with our tensioner making a chattering sound at low rpms like 1,000 to 2000 rpm range and it will be gone.</p><p></p><p>When you change your clutch, did the mechanic remove your tensioner and tighten it back? If he touched the tensioner, then its highly probably that its the culprit bcos you need certain force applied to tighten the tensioner. Too tight or not tight enough will make it make chattering sound.</p></blockquote><p></p>
[QUOTE="dawg, post: 4217638, member: 839"] I'm assuming the chatter sound maybe be from the tensioner instead of knocking. If your A/F ratio is 11-12 you are on the rich side. Stoich is 14.7 and lean would be above 14.7 ... Evos tend to have this problem with our tensioner making a chattering sound at low rpms like 1,000 to 2000 rpm range and it will be gone. When you change your clutch, did the mechanic remove your tensioner and tighten it back? If he touched the tensioner, then its highly probably that its the culprit bcos you need certain force applied to tighten the tensioner. Too tight or not tight enough will make it make chattering sound. [/QUOTE]
R35 Used Titanium Exhaust
Throwing off the cat for 8.
It's really HOT especially during traffic jam on the center console. Some said removing the cat will help.
1) Is this myth true?
2) What is the side effect?
3) Will the CEL lite up after cat removed?
Thank you!
evo bodywork
hi,need recommendation on where a good place/shop to carry out bodywork repair after accident for evo.thanks.
New Dashboard
One of our bros in Singapore (blitezza) replaced his dashboard...just wondering, do we have an expert here who can do the job without damaging the new one? Has anyone done it over here?
Car Clubs
Car Club Categories
