The water pump is attached to your engine block. Your radiator has two radiator hose rite ? 1 of going into the radiator and 1 is out. usually the hose on the top of the radiator is connected to the water pump. you can see it.
Went to a spare part shop to look for a timing belt for 4G93T, the spare part shop was unsure as he mention there are two different teeth (Gigi) of timing belt. One of them has 153 teeth and 154 teeth for...
hi can anyone tell me what's the stock max boost for an evo 8 on WOT? the car is pretty stock with no mods except air filter, and a straight flow exhaust.
