Main Forums
Car Talk
Forced Induction & Engine Management
supercharging an engine
<blockquote data-quote="JCV" data-source="post: 1063474346" data-attributes="member: 93546"><p>Mine SC was taken from Estima Buyong/1G-GZE (old estima), Code Name SC14 displacing 1420cc per revolution (220cc more than the 4A-GZE supercharger), toyota oso have another SC from 4A-GZE Code Name SC12 displaces 1200cc per revolution.</p><p></p><p>Everything need to custom like </p><p>a) custom bracket</p><p>b) custom piping + hose </p><p>c) inter-cooler (optional)</p><p>d) engine belting (long)</p><p>e) ABV - Air ByPass Valve</p><p></p><p>Throttle Body placement </p><p>Advisable fix it b4 SC</p><p>MAF -> TB -> SC/Blower -> FMIC/TMIC -> Intake Plenum </p><p></p><p>Air/Fuel/Ignition Control </p><p>Using piggy back, i am using E-manage Ultimate pair with V-manage (for valve timing)</p><p></p><p>Others than that still stock internal (xcept for lightweight pulley, forge radiator)</p><p></p><p>For the beginning i am getting 0.4 bar, after change to small pulley, now running 0.6 bar</p><p>b4 SC (original standard only a piggy back) 148hp, after SC dunno because not yet dyno.</p><p>Only done road tuning, tuned by torque racing permas jaya (ah-cuan).</p><p></p><p><img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/driver.gif" class="smilie" loading="lazy" alt=":driver:" title="Driver :driver:" data-shortname=":driver:" /></p></blockquote><p></p>
[QUOTE="JCV, post: 1063474346, member: 93546"] Mine SC was taken from Estima Buyong/1G-GZE (old estima), Code Name SC14 displacing 1420cc per revolution (220cc more than the 4A-GZE supercharger), toyota oso have another SC from 4A-GZE Code Name SC12 displaces 1200cc per revolution. Everything need to custom like a) custom bracket b) custom piping + hose c) inter-cooler (optional) d) engine belting (long) e) ABV - Air ByPass Valve Throttle Body placement Advisable fix it b4 SC MAF -> TB -> SC/Blower -> FMIC/TMIC -> Intake Plenum Air/Fuel/Ignition Control Using piggy back, i am using E-manage Ultimate pair with V-manage (for valve timing) Others than that still stock internal (xcept for lightweight pulley, forge radiator) For the beginning i am getting 0.4 bar, after change to small pulley, now running 0.6 bar b4 SC (original standard only a piggy back) 148hp, after SC dunno because not yet dyno. Only done road tuning, tuned by torque racing permas jaya (ah-cuan). :driver: [/QUOTE]
R35 Used Titanium Exhaust
Looking: E456 ori front strut bar
deleted.........
Controlling boost using fish tank valves...
Hey guys.
I tried using a ball bearing and spring-type boost controller, but the spike was way too high at 1.5 and the boost isnt constant. So my mechanic resorted to fish tank valves x2.
Now the boost spike is...
[DIY] Replacing Suspension Bushes & Links
Cost:
Front ARB link + bushes (satay bush), RM7/set x 2
Rear ARB link (2 ball joins, satria), RM45/set x 1
Tools:
14mm & 15mm spaners & rachet
5mm hex key head and adaptor to rachet
G-clamp
Car jack...
Main Forums
Car Talk
