Main Forums
General Talk
Super Pro for Accord CF4
<blockquote data-quote="Sato" data-source="post: 2103413" data-attributes="member: 4147"><p>Chris2000,</p><p></p><p>Do you have SuperPro for CF4 antiroll bar then ? I've changed the antiroll bar to cusco front and rear.....</p><p></p><p>But the mechanic put back the original honda bush la.....it's not the same size....and it's going weaker now....</p><p></p><p>the front antiroll bar is 300mm and rear is 180mm</p><p></p><p>thanks</p></blockquote><p></p>
[QUOTE="Sato, post: 2103413, member: 4147"] Chris2000, Do you have SuperPro for CF4 antiroll bar then ? I've changed the antiroll bar to cusco front and rear..... But the mechanic put back the original honda bush la.....it's not the same size....and it's going weaker now.... the front antiroll bar is 300mm and rear is 180mm thanks [/QUOTE]
david tao
RCA Track Day 23/7/10 1230 - 1530
RCA Track Event Friday 23rd July 2010, 1230-330pm
Next RCA track day is unfortunately on a week...
SA22C for sale
Hi All,
I have an SA22C for sale. Please view images and specs below.
I can be contacted at 012 327 0577 for more details.
Thanks.
bgr
Reg no: XXX YY88
SA22 reg.1980
Engine:
12A
Weber 48 IDA downdraught carb...
Custom wheel hubs and driveshaft assembly
Just want to ask a few questions here.
Will the wheel hubs and driveshaft from 2 different manufacturers match? Example, will a Toyota drivashaft bolt right on a Mitsu wheel hub? Correct me if I'm wrong, the...
Main Forums
General Talk
