Main Forums
Interests
ICE
subs with humming sounds...
<blockquote data-quote="Zenn" data-source="post: 1973139" data-attributes="member: 15503"><p>check first the amp's grounding. when u said powered sub i assume the amp is inbuilt with the box, so connection is pretty straightforward, just that the grounding point must be good (good contact, free of paint, suitable wire size, etc). if this is ok then it could well be rca wire is picking up engine rev signals into the music signals, best to separate them from power cables, or if theres an ecu nearby the wire, best to re-route it away.</p></blockquote><p></p>
[QUOTE="Zenn, post: 1973139, member: 15503"] check first the amp's grounding. when u said powered sub i assume the amp is inbuilt with the box, so connection is pretty straightforward, just that the grounding point must be good (good contact, free of paint, suitable wire size, etc). if this is ok then it could well be rca wire is picking up engine rev signals into the music signals, best to separate them from power cables, or if theres an ecu nearby the wire, best to re-route it away. [/QUOTE]
david tao
Original Or Fake
solved
Driveshaft rebuild shop
Guys,
Anyone know where i can get my driveshaft rebuild?
My waja RH driveshaft is worn out and i have replaced it with aftermarket brand but it vibrates..I claim warranty and the replacement shaft still vibrate but...
WTB:R32 GTR ABS master pump..
Dear all,
Helping a friend to look for a R32 GTR Vspec||
ABS master pump only
. Pls see pics below, item in in the yellow box.
Pls
sms
Main Forums
Interests
ICE
