Main Forums
Car Talk
Strange overheating problem
<blockquote data-quote="vr2turbo" data-source="post: 1064699404" data-attributes="member: 92229"><p>This thermostat should be at the radiator to trigger the fan, The other one you change is to control system circulation....<img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/driver.gif" class="smilie" loading="lazy" alt=":driver:" title="Driver :driver:" data-shortname=":driver:" /></p></blockquote><p></p>
[QUOTE="vr2turbo, post: 1064699404, member: 92229"] This thermostat should be at the radiator to trigger the fan, The other one you change is to control system circulation....:driver: [/QUOTE]
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
original rare Yokohama ADVAN Racing RG3 18x8.5jj...
david tao
~accident repair ~touch up paint
jeff6126
Factory Service Manuals (FSM's) Downloadable
I will add more FSM's as i hunt em down:
Feel Free to add more links to FSM on the web that you find here:
Tevs
The links are usually in PDF format - make sure you can read PDF's - it's a mix of Manuals and books...
DIY installing RSM
Just bought 1st edition RSM (from ZTH) and figure to DIY installing it.
Took some pic to share..hehe
First.. you must have RSM la off course.. so this is mine..
Then find the manual...
Can you put auto-leveling HIDs in a car stocked with halogens?
I just bought a HID entire headlight assembly (not just conversion kit) off of ebay. It appears that the xenon light is on a swivel hinge because it can move up and down inside the assembly. I've heard that many cars...
Main Forums
Car Talk
