Car Clubs
Car Club Categories
The Altezza / IS200 / IS300 Forum
Starting problem
<blockquote data-quote="flatlander" data-source="post: 4208371" data-attributes="member: 11595"><p>Hi all, thanks for your advices..really appreciate it..</p><p>By the way, I think I've found the cause of the problem, it was the starter fuse that have blown. It seems the previous owner did jump the blown fuse using a thin wire, and perhaps just so happen to me that the wire was not properly contact with the terminal. Replace the fuse, and now its working fine so far.</p><p></p><p>Thank you..</p></blockquote><p></p>
[QUOTE="flatlander, post: 4208371, member: 11595"] Hi all, thanks for your advices..really appreciate it.. By the way, I think I've found the cause of the problem, it was the starter fuse that have blown. It seems the previous owner did jump the blown fuse using a thin wire, and perhaps just so happen to me that the wire was not properly contact with the terminal. Replace the fuse, and now its working fine so far. Thank you.. [/QUOTE]
R35 Used Titanium Exhaust
Semi auto or manual ??
Been modding till stage 2 . Semi auto gear box start to clutch slip . And circlip bearing broken need to be fix . What do you guys think ? Semi auto or manual Awd ? Cos price to fix the semi auto gear box are round...
Babes: A1GP Malaysia 2007 - Sepang Circuit
Flag
So the...
CLutch Discussion
Guys,
i'm here to start a discussion about clutches on our RE powered ladies...
okay... i tried before only 2 clutches,
1) exedy oem clutch - the feeling is like stock but it engages earlier than stock.. lift half...
Car Clubs
Car Club Categories
Starting problem
