Main Forums
Car Talk
Forced Induction & Engine Management
SR20 DET problem
<blockquote data-quote="TE27levin" data-source="post: 199849" data-attributes="member: 713"><p>idle up valve? water tamp and air temp.. this three thing will cause the problem.</p><p>this always happen to turbo car..</p><p>i just base on my toyota engine experience i dunno about SR, the idle valve will close when water temp is hot. </p><p>so after i drive, off engine turbo engine is slow to cool down cos engine bay is very hot. so air temp sensor will heated up. water temp also heat up cos the head will get hoter due to exhaust manifold heat will transfer heat... so when start engine ecu will not think it was cold start..</p><p></p><p>hope this give u some idea.. maybe it dont help also :D :P</p></blockquote><p></p>
[QUOTE="TE27levin, post: 199849, member: 713"] idle up valve? water tamp and air temp.. this three thing will cause the problem. this always happen to turbo car.. i just base on my toyota engine experience i dunno about SR, the idle valve will close when water temp is hot. so after i drive, off engine turbo engine is slow to cool down cos engine bay is very hot. so air temp sensor will heated up. water temp also heat up cos the head will get hoter due to exhaust manifold heat will transfer heat... so when start engine ecu will not think it was cold start.. hope this give u some idea.. maybe it dont help also :D :P [/QUOTE]
R35 Used Titanium Exhaust
Mitsubishi Lancer Evolution X vs. Subaru Impreza WRX STI
http://www.roadandtrack.com/assets/image/2007/Q2/4192007192038.jpg
The rally continues between Mitsubishi Evolution X and Subaru Impreza WRX STi...
At...
Season Greetings !!
Dear all,
To all MLOC members and fellow ZTH forummers..
I would like to take this opportunity to wish those of you celebrating the upcoming Christmas a "Merry Christmas" and for those celebrating the upcoming Hari...
Tein adjustable front caster rod.
1 pair of S13/180sx Tein adjustable front caster rod.
Selling for Rm280.
Interested pls call 012-322 8484.
http://i88.photobucket.com/albums/k182/GT1580/DSCN0330.jpg...
sn964444
Main Forums
Car Talk
SR20 DET problem
