Main Forums
Car Talk
Car Modification
Spot & seam welded body..
<blockquote data-quote="sexycar" data-source="post: 438484" data-attributes="member: 2014"><p>wow... thanks olskool.. but quality really bad.... I think its very</p><p>usefull... too bad cant see clearly... if u use a scanner than it will</p><p>be alright.</p></blockquote><p></p>
[QUOTE="sexycar, post: 438484, member: 2014"] wow... thanks olskool.. but quality really bad.... I think its very usefull... too bad cant see clearly... if u use a scanner than it will be alright. [/QUOTE]
david tao
Just found out what M in M-Spec stands for.
The M-Spec has been on sale since the 8th of, 2001 and is the result of the first change to the GT-R made by the new team of engineers headed by Kazutoshi
M
izuno (the former chief engineer at Nissan Le...
38mm wastegate suitable for 1.5 bar boost?
need advice 38mm wastegate suitable for 1.5 bar boost?
pls advice all bro..izzit suitable to use 38mm china external wastegate on td05h turbine in 1.5 bar boost?need advice on it..thanks..
Diy : Superlon Installation
This is SuperLon.
Southern Malaysia, you can get your SuperLon from Stanley.
Northern, I have 1/4 roll left, can get from Me.
Step 1 : Measure the amount of SuperLon you need. DO NOT cut it yet. Just measure and...
Main Forums
Car Talk
Car Modification
