Car Brands
Car Manufacturers
Toyota
Speedometer with speed sensor 4AGE 16v
<blockquote data-quote="iamiceman" data-source="post: 1063449383" data-attributes="member: 41054"><p>Update: Went over to Wai and Lin workshop in Puchong last Sat to get the error code 42 checked. Seems like the only way to solve it is to open up my current meter, dig out 2 wire from inside and then reconnect them to the ECU. Something to do with my meter is the cable type and hence missing the sensor wire(not exactly sure what is the exact word he used). </p><p></p><p>I had to put the project on hold as it will cost a fair bit. According to Wai, he can settle it within 1 day. I'll update again once I have got the problem settled.</p></blockquote><p></p>
[QUOTE="iamiceman, post: 1063449383, member: 41054"] Update: Went over to Wai and Lin workshop in Puchong last Sat to get the error code 42 checked. Seems like the only way to solve it is to open up my current meter, dig out 2 wire from inside and then reconnect them to the ECU. Something to do with my meter is the cable type and hence missing the sensor wire(not exactly sure what is the exact word he used). I had to put the project on hold as it will cost a fair bit. According to Wai, he can settle it within 1 day. I'll update again once I have got the problem settled. [/QUOTE]
david tao
Michelin ups the ante on the competition
https://www.zerotohundred.com/wp-content/uploads/2010/05/Michelin-Pilot-Sport-3-Launch-Thailand-54-600x398.jpg
It doesn’t matter if your car is fast; it doesn’t matter if your car has 300, 500, 800, or even 1000...
Advise for mild mods
Hi
For Evo 7 , meant for daily drive
Just need to add a little more power
Target reliable 320bhp only. ..need generous torque at mid range RPM.
What item & mod should I do ?
Thanks
Where to buy new Carpet for my old car..
I plan to change my old car carpet ...
Does everyone know where I want to buy ...
Really want to change before raya !!!
Car Brands
Car Manufacturers
Toyota
