Main Forums
Car Talk
Car Modification
spark plug gap...
<blockquote data-quote="Joeker" data-source="post: 2461565" data-attributes="member: 591"><p>1st. Get a spark plug filler blade set. (the same tool that is used to dial-in the valvetrain tappet gaps)</p><p></p><p>2nd. Gap the plugs according to the manufacturer's spec.</p><p></p><p>3rd. If you've raised the boost pressure, its advisable to go a step down (narrower) to avoid missing.</p><p></p><p>Increasing the gap width makes the spark harder to arch and increasing the likeliness of missing.</p><p></p><p>PS : Don't know the correct gap? check your car's engine manual. It will mention the gap and plug type for your engine.</p></blockquote><p></p>
[QUOTE="Joeker, post: 2461565, member: 591"] 1st. Get a spark plug filler blade set. (the same tool that is used to dial-in the valvetrain tappet gaps) 2nd. Gap the plugs according to the manufacturer's spec. 3rd. If you've raised the boost pressure, its advisable to go a step down (narrower) to avoid missing. Increasing the gap width makes the spark harder to arch and increasing the likeliness of missing. PS : Don't know the correct gap? check your car's engine manual. It will mention the gap and plug type for your engine. [/QUOTE]
R35 Used Titanium Exhaust
RX-8 Club teases with trailers for mega gathering showcase
[FONT="]https://www.zerotohundred.com/wp-content/uploads/2011/01/rx8-600x360.jpg
It would appear to have been a busy year end of 2010 for the local chapter of the Mazda RX-8 club as the piston-less posse...
Swap 1JZ Auto
Happy New Year to all member.
New year have new plan for my tezza.i am plan to swap auto 1jz,any one done before?
what i should change?meter????and other?currently my tezza is manual 6 speed .
Mods / Diy
how to do this diy? can do? where to buy stuff?
http://www.h-maki.info/dks/sagyou/020.htm
this 1 also want repair viper how do eh ?
http://www.h-maki.info/dks/sagyou/001.htm
Main Forums
Car Talk
Car Modification
spark plug gap...
