Main Forums
Car Talk
Forced Induction & Engine Management
soft turbo?
<blockquote data-quote="kambing69" data-source="post: 1063795884" data-attributes="member: 118685"><p>thank's for the input ssrotel . . and for remind me about the compression. Will noted that. . Im not going for sc for now because what im trying to achieve is to make a car that can save petrol (well if drive properly below 4k RPM) then can go wildly fast above that. </p><p></p><p>So if around 2000RPM turbine already spooling, IMO that very good , since my gearing already in short ratio...... and i think that kinda bad for FI... or any other input?</p><p></p><p>My target was to make it responsive as possible in every gear and RPM (minimize lagging) </p><p></p><p>1 more thing, is there any Variable turbo aftermarket setup now?</p></blockquote><p></p>
[QUOTE="kambing69, post: 1063795884, member: 118685"] thank's for the input ssrotel . . and for remind me about the compression. Will noted that. . Im not going for sc for now because what im trying to achieve is to make a car that can save petrol (well if drive properly below 4k RPM) then can go wildly fast above that. So if around 2000RPM turbine already spooling, IMO that very good , since my gearing already in short ratio...... and i think that kinda bad for FI... or any other input? My target was to make it responsive as possible in every gear and RPM (minimize lagging) 1 more thing, is there any Variable turbo aftermarket setup now? [/QUOTE]
Hunting for an Unreg. Re-cond Altezza
available?
any idea on the price?
tq.
[WTB] RX-7 FD3S (cash)
Recently i've decided to get a 2nd car. After 3 months of intensive reading and research into the rotary based 7th, i've decided to invest on one myself and fuel consumtption is least of the problem because i...
Best fuel for Skylines?
What are the RON ratings in Malaysian gas stations?
Shell V-max = 97 RON?
Mobil Synergy?
Petronas?
Caltex?
BP?
etc....
Also what have do u fellow skylines use and which is ur favourite or recommendations??
Main Forums
Car Talk
soft turbo?
