Main Forums
Interests
Do-It-Yourself Garage
Side indicator blink speed
<blockquote data-quote="Maxx" data-source="post: 2612200" data-attributes="member: 9513"><p>hmm..</p><p>lets see if my formula is rite..</p><p></p><p>21W </p><p>W=V*I , 21=12*I</p><p>I=W/V , 1.75 = 21/12, each bulb consume about 1.75A</p><p></p><p>3W</p><p>I=3/12 , 0.25=3/12, each 3W led only consume 0.25A</p><p></p><p>so, 1.75 - 0.25 = 1.5A, need to dissipate about 1.5A at each bulb thats has been replaced by LED.</p><p></p><p>V=I*R</p><p>R=V/I , 8=12/1.5, each LED needs 8ohm resistor parallel to it. </p><p></p><p>eh, is this rite? 8ohms at each LED bulb?:hmmmm: <img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/confused.gif" class="smilie" loading="lazy" alt=":confused:" title="Confused :confused:" data-shortname=":confused:" /></p><p>btw, resistor use should be at least 3W ceramic type . </p><p></p><p>btw, im not sure this is rite or wrong. 8ohms seems to low value.</p><p>need others to give opinion/ideas.</p><p></p><p>other alternative u can modify the stock (or spare) flasher relay.</p><p>try using different capacitor value inside the relay. im not sure either higher or lower value. forgot already.</p></blockquote><p></p>
[QUOTE="Maxx, post: 2612200, member: 9513"] hmm.. lets see if my formula is rite.. 21W W=V*I , 21=12*I I=W/V , 1.75 = 21/12, each bulb consume about 1.75A 3W I=3/12 , 0.25=3/12, each 3W led only consume 0.25A so, 1.75 - 0.25 = 1.5A, need to dissipate about 1.5A at each bulb thats has been replaced by LED. V=I*R R=V/I , 8=12/1.5, each LED needs 8ohm resistor parallel to it. eh, is this rite? 8ohms at each LED bulb?:hmmmm: :confused: btw, resistor use should be at least 3W ceramic type . btw, im not sure this is rite or wrong. 8ohms seems to low value. need others to give opinion/ideas. other alternative u can modify the stock (or spare) flasher relay. try using different capacitor value inside the relay. im not sure either higher or lower value. forgot already. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
All-New 2009 Toyota Corolla Debut at SEMA
http://images.worldcarfans.com/articles/2007/10/31/9071031.053/9071031.053.1M.jpg
Toyota Motor Sales (TMS), U.S.A., Inc., unveiled the all-new 10th generation Corolla sedan at a press conference today at the 2007...
TT Gathering - 25 August 2006
Dear All,
Shall have another round of a short trip this Friday? :X-:
Date: This Friday, 25 August 2006
Time: 8.30pm-10.30pm
Venue: Medan Sunway Food Court.
... See you there.....
who intrest to let Japanese tuner o setting yr car n mgmt?
any one intres to get Nishimiya San fr Quatermile Hi Perfomance Factory Japan and RH9 to tune or set yr Power FC,HKS F Con V pro or SZ,e manage or use NEKO Soft ware to remap yr oem ecu.....
he use apexi power...
Main Forums
Interests
