Main Forums
Car Talk
Short stroke? Long Stroke?? Shocks??
<blockquote data-quote="LuKa" data-source="post: 2049473" data-attributes="member: 15619"><p>"Stock Springs + Short-stroke absorbers = Bad</p><p>This is a very good example of penis-elongation pill a.k.a. Viagra, only it is in absorber-term."</p><p></p><p>i have to disagree.. </p><p></p><p>performance n ride wise will be a bit hard than stock,but still comfortable.. but ride height combo of short stroke shocks+lowered springs will not be convenient.. scraping n ground clearance of over speed breaker,bumps n potholes will occur</p></blockquote><p></p>
[QUOTE="LuKa, post: 2049473, member: 15619"] "Stock Springs + Short-stroke absorbers = Bad This is a very good example of penis-elongation pill a.k.a. Viagra, only it is in absorber-term." i have to disagree.. performance n ride wise will be a bit hard than stock,but still comfortable.. but ride height combo of short stroke shocks+lowered springs will not be convenient.. scraping n ground clearance of over speed breaker,bumps n potholes will occur [/QUOTE]
david tao
4G93T Problem when Boost Kick In
Hi all sifu, wanna get advice from you all, I have the following problem after I have upgrade my fuel pump to walbro.
boost kick in then until 4K rpm suddenly turbo lag for 1K rpm range then boost come in again...
SR20DET from Nissan U13
can some Nissan sifu provide me with info on this particular engine?
Float Up Bonnet
guys and sifu here....my car is LMST i want to float up the front bonet about 1CM gap. Purpose is not to show off or what but i really need the air circulation because i am using Apexi Open Port. Really need to...
Main Forums
Car Talk
