The Marketplace Categories
Selling n96 rm1900
<blockquote data-quote="marleyz" data-source="post: 3280477" data-attributes="member: 22644"><p>ap set...used for 1month and fullset and is in good condition....0123456497 sham</p></blockquote><p></p>
[QUOTE="marleyz, post: 3280477, member: 22644"] ap set...used for 1month and fullset and is in good condition....0123456497 sham [/QUOTE]
david tao
*water temperature sensor voltage low* proton persona
need help from all master
as topic,
persona B line (M)
start engine RPM run to 8k can drive but agar 3k rpm then cut off.
use OD check error code water temperature sensor voltage low.
i change the sensor, few hours...
4g93t gsr ecu pin out
who have 4g93t ecu pin out map pls post it
ecu number is 7395
haltech e6x ecu problem.
i got 1 e6x and e6k got problem with ic who can help me .e6k is always burn coil .
Selling n96 rm1900
