Main Forums
General Talk
Satria Neo problems. HELP!
<blockquote data-quote="kcng" data-source="post: 1063774092" data-attributes="member: 63184"><p>for the Headunit, just turn off RDS... problem solve..</p><p></p><p>front speaker no sound?</p><p>check the head unit and see if the bias is set completely to the back?</p><p></p><p>as for the auto rev?</p><p>welcome to proton drive-by-wire configuration</p><p>:D</p><p>its the ECU that is doing all this.... </p><p>dont worry, its normal.....</p><p>:)</p></blockquote><p></p>
[QUOTE="kcng, post: 1063774092, member: 63184"] for the Headunit, just turn off RDS... problem solve.. front speaker no sound? check the head unit and see if the bias is set completely to the back? as for the auto rev? welcome to proton drive-by-wire configuration :D its the ECU that is doing all this.... dont worry, its normal..... :) [/QUOTE]
david tao
Pagani teases with second C9 video that reveals name
http://www.zerotohundred.com/?attachment_id=17316
Just as the internet rumour mills hit overdrive to speculate that the upcoming Pagani Zonda replacement, currently codenamed C9, could be called the Huayra, the...
where can i buy fd3s spark plugs??
wat kind of spark plugs does fd3s use? wat's the price like? thx for the help...
Nissan's Zama storage facility
One lucky Nissan 300ZX twin turbo fan was recently able to tour the manufacturer's famed Zama Operations Center in Kanagawa, Japan. The location is...
Main Forums
General Talk
