Main Forums
Car Talk
Satria 1.5 auto to 4G93/4G93P (NA) manual!!!
<blockquote data-quote="Viera Sasaki" data-source="post: 1063438302" data-attributes="member: 111540"><p>Well, not in term of stock actually. What I meant to say is 4G93 have a plenty of modification u can do with a less risk and money compared to 4G92 MIVEC. Here is a factory spec btwn 4G92 and 4G93 series engine:</p><p></p><p>4G92 DOHC 16 Valve</p><p></p><p>* Total Displacement - 1597cc</p><p>* Bore - 81.0mm</p><p>* Stroke - 77.5mm</p><p>* Compression Ratio - 11:1</p><p>* Maximum Output - 108 kW (147 PS; 145 bhp) @ 7000 rpm</p><p>* Maximum Torque - 149 N·m (110 ft·lbf) @ 4500 rpm</p><p></p><p>4G92-MIVEC DOHC 16 Valve</p><p></p><p>* Total Displacement - 1597cc</p><p>* Bore - 81.0mm</p><p>* Stroke - 77.5mm</p><p>* Compression Ratio - 11:1</p><p>* Maximum Output - 128 kW (174 PS; 172 bhp) @ 7,500 rpm</p><p>* Maximum Torque - 167 N·m (123 ft·lbf) @ 7,000 rpm</p><p></p><p>4G93 DOHC 16 Valve</p><p></p><p>* Gasoline Direct Injection (GDI)</p><p>* Total Displacement - 1834cc</p><p>* Bore - 81.0mm</p><p>* Stroke - 89.0mm</p><p>* Compression Ratio - 12:1</p><p>* Maximum Output - 96 kW (131 PS; 129 bhp) / 103 kW (140 PS; 138 bhp) @ 6,000 rpm</p><p>* Maximum Torque - 177 N·m (131 ft·lbf) @ 3,750 rpm / 181 N·m (133 ft·lbf) @ 3,500 rpm</p><p></p><p>4G93 DOHC 16 Valve Turbocharged</p><p></p><p>* TD04 turbocharger variant</p><p>* Total Displacement - 1834cc</p><p>* Bore - 81.0mm</p><p>* Stroke - 89.0mm</p><p>* Compression Ratio - 8.5:1</p><p>* Maximum Output - 143 kW (194 PS; 192 bhp) @ 6,000 rpm</p><p>* Maximum Torque - 270 N·m (200 ft·lbf) @ 3,000 rpm</p><p></p><p>***Credit goes to Wikipedia.org***</p><p></p><p>Why don't u try this: http://www.mudah.my/Mivec4g93-8662924.htm</p><p></p><p></p><p></p><p>The price is around RM4000 to RM6000++, depending on the condition of the engine.</p></blockquote><p></p>
[QUOTE="Viera Sasaki, post: 1063438302, member: 111540"] Well, not in term of stock actually. What I meant to say is 4G93 have a plenty of modification u can do with a less risk and money compared to 4G92 MIVEC. Here is a factory spec btwn 4G92 and 4G93 series engine: 4G92 DOHC 16 Valve * Total Displacement - 1597cc * Bore - 81.0mm * Stroke - 77.5mm * Compression Ratio - 11:1 * Maximum Output - 108 kW (147 PS; 145 bhp) @ 7000 rpm * Maximum Torque - 149 N·m (110 ft·lbf) @ 4500 rpm 4G92-MIVEC DOHC 16 Valve * Total Displacement - 1597cc * Bore - 81.0mm * Stroke - 77.5mm * Compression Ratio - 11:1 * Maximum Output - 128 kW (174 PS; 172 bhp) @ 7,500 rpm * Maximum Torque - 167 N·m (123 ft·lbf) @ 7,000 rpm 4G93 DOHC 16 Valve * Gasoline Direct Injection (GDI) * Total Displacement - 1834cc * Bore - 81.0mm * Stroke - 89.0mm * Compression Ratio - 12:1 * Maximum Output - 96 kW (131 PS; 129 bhp) / 103 kW (140 PS; 138 bhp) @ 6,000 rpm * Maximum Torque - 177 N·m (131 ft·lbf) @ 3,750 rpm / 181 N·m (133 ft·lbf) @ 3,500 rpm 4G93 DOHC 16 Valve Turbocharged * TD04 turbocharger variant * Total Displacement - 1834cc * Bore - 81.0mm * Stroke - 89.0mm * Compression Ratio - 8.5:1 * Maximum Output - 143 kW (194 PS; 192 bhp) @ 6,000 rpm * Maximum Torque - 270 N·m (200 ft·lbf) @ 3,000 rpm ***Credit goes to Wikipedia.org*** Why don't u try this: http://www.mudah.my/Mivec4g93-8662924.htm The price is around RM4000 to RM6000++, depending on the condition of the engine. [/QUOTE]
R35 Used Titanium Exhaust
Airtrek Turbo subframe
Hi All Sifu,
i have something need to ask and know about our Airtrek subframe (front) & (rear).
Our front subframe if want to convert to EVO, version 7 to 9 is can fix, right? if only take the EVO lower arm to fix on...
ECU learns
http://www.350z-tech.com/forums/index.php?showtopic=25195
thought id share something i just read..its about how the stock ECU learns our driving habit..i think..
Altezza 2JZ Drift (5mins video)
Claimed to have 570hp (2JZ):confused_smile:
Main Forums
Car Talk
