Main Forums
Interests
Do-It-Yourself Garage
Saga Power windows problem
<blockquote data-quote="Skyfiro A32" data-source="post: 3951262" data-attributes="member: 52954"><p>nope,not blm is the 1st version saga..teksi saga<span style="color: Silver"></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"><span style="font-size: 9px">---------- Post added at 09:31 AM ---------- Previous post was at 09:29 AM ----------</span></span></p><p><span style="color: Silver"></span></p><p><span style="color: Silver"></span>i tried to change the battery,but..my power window stil not working..i pull a direct power supply from battery with fuse to the motor,its work well..so its mean the motor is work well rite?if yes,den wat is the problem wit the power window?<img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/confused.gif" class="smilie" loading="lazy" alt=":confused:" title="Confused :confused:" data-shortname=":confused:" /></p></blockquote><p></p>
[QUOTE="Skyfiro A32, post: 3951262, member: 52954"] nope,not blm is the 1st version saga..teksi saga[COLOR="Silver"] [SIZE=1]---------- Post added at 09:31 AM ---------- Previous post was at 09:29 AM ----------[/SIZE] [/COLOR]i tried to change the battery,but..my power window stil not working..i pull a direct power supply from battery with fuse to the motor,its work well..so its mean the motor is work well rite?if yes,den wat is the problem wit the power window?:confused: [/QUOTE]
R35 Used Titanium Exhaust
Car cannot start
Car unable to start after three months sitting idle. Negatif connection on battery was removed. What could be the reason. Lights , side mirror working. Clicking sound is there
Sent from my SM-N910C using Tapatalk
MSN Live messenger
wondering if we can put our MSN messenger account here so that we can talk about everything about Tezza on the air....
1.
[email protected]
(aycy)
2.
gear knob
i have a screw on type gear knob(hope u all know what i mean, heh heh)...
due to constant gear shifting, the gear knob will loosen after some time which i have to rescrew it back(very annoying)..
recently i found...
Main Forums
Interests
