Main Forums
Interests
Motorsport Specifics
Drifting
RWD halfcut engine...
<blockquote data-quote="aircooled" data-source="post: 404116" data-attributes="member: 3840"><p>u need a lot of money for big hp in a beetle....aircooled way. say, 40-50K. even that, u will still need extra for spare parts in case of broken stuff.</p><p></p><p>new case US 400-650</p><p>crankshaft US400 big dtroke forged</p><p>rods H beam US300</p><p>camshaft US100</p><p>lifters US 80-US450</p><p>pistons US200 to US2000....yes US2000!! for pistons</p><p>studs US 60</p><p>heads US700 - US3000 depending on your application</p><p>rockers US 400 - US700 depending on brand, lift, material, quality</p><p>clutch - US 80 - US 300</p><p>full flow filter set US150 plus additional for washable filter used in drag cars....eg Oberg or System 1</p><p>Carburators - US 1000 plus extra cash for jetting, spares </p><p>MSD ignition US 600 for full set OR</p><p></p><p>EFI fuel n ignition - programmable ...can get from Sunway shops Microtech,haltech but u need to buy throttle bodies yourself.</p><p></p><p>that will give you about 200 bhp if done correctly. </p><p></p><p>if u want cheaper options, u can go for Japanese engine conversion, Subaru, RX7...muh cheaper and feasible for us malaysians. turbo is good....a few running already.</p><p></p><p>but then, u will stilla lot of mony forthe gearbox.</p><p></p><p>Quaiffe LSD is about 1000 pounds i think depending on type of box.</p></blockquote><p></p>
[QUOTE="aircooled, post: 404116, member: 3840"] u need a lot of money for big hp in a beetle....aircooled way. say, 40-50K. even that, u will still need extra for spare parts in case of broken stuff. new case US 400-650 crankshaft US400 big dtroke forged rods H beam US300 camshaft US100 lifters US 80-US450 pistons US200 to US2000....yes US2000!! for pistons studs US 60 heads US700 - US3000 depending on your application rockers US 400 - US700 depending on brand, lift, material, quality clutch - US 80 - US 300 full flow filter set US150 plus additional for washable filter used in drag cars....eg Oberg or System 1 Carburators - US 1000 plus extra cash for jetting, spares MSD ignition US 600 for full set OR EFI fuel n ignition - programmable ...can get from Sunway shops Microtech,haltech but u need to buy throttle bodies yourself. that will give you about 200 bhp if done correctly. if u want cheaper options, u can go for Japanese engine conversion, Subaru, RX7...muh cheaper and feasible for us malaysians. turbo is good....a few running already. but then, u will stilla lot of mony forthe gearbox. Quaiffe LSD is about 1000 pounds i think depending on type of box. [/QUOTE]
david tao
stock rims tyre
hi all,
the standard tyre size for our stock rims is 215/45/17 right? how about if i put in 225/45/17. if there any much different in handling, looks, etc?
please advice..:hmmmm:
What engine, gearbox, auto tranny, LSD oil you using?
Thanks for sharing and hope this is useful to all skyline freshy(me) and upcoming skyliner who plan to own one.
Turbo Manifold Glow
Is it normal for the manifold to glow
Mine glows if i booost 1bar
if i boost 0.7 it looks fine
What does that glowing mean ?
What to do ?
thanks
Main Forums
Interests
Drifting
