Car Brands
Car Manufacturers
Toyota
RSR Spring Let Go
<blockquote data-quote="8313" data-source="post: 1719519" data-attributes="member: 32749"><p>wat da last price...</p><p>pm me plz,.............</p><p>yhx</p></blockquote><p></p>
[QUOTE="8313, post: 1719519, member: 32749"] wat da last price... pm me plz,............. yhx [/QUOTE]
david tao
*water temperature sensor voltage low* proton persona
need help from all master
as topic,
persona B line (M)
start engine RPM run to 8k can drive but agar 3k rpm then cut off.
use OD check error code water temperature sensor voltage low.
i change the sensor, few hours...
4g93t gsr ecu pin out
who have 4g93t ecu pin out map pls post it
ecu number is 7395
haltech e6x ecu problem.
i got 1 e6x and e6k got problem with ic who can help me .e6k is always burn coil .
Car Brands
Car Manufacturers
Toyota
RSR Spring Let Go
