Car Brands
Car Manufacturers
Honda
Rsm , Vafc
<blockquote data-quote="BobcatSysOp" data-source="post: 1103932" data-attributes="member: 22244"><p>Here is just some information on how RSM works and G-sensors do.</p><p>(RSM) Rev/Speed Meter measures and monitors data such as vehicle speed, engine RPM, and elapsed times. The screen uses the easy to read VFD (Vacuum Fluorescent Display) with built in light sensor used in many of A'PEX's line up. Standard features include: Engine RPM, Vehicle Speed, Travel Distance, and Battery Voltage (All which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time.), Peak Hold, Replay (With 60 second playback.), Speed Limiter Cut, 0-100m/200m/400m times with trap speed, 0-100km/h/200km/h/300km/h times, Mid Range Acceleration (The user can preset any range of speed to measure.), Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM and Speed Outputs (For external devices requiring an RPM or speed signal like a shift light.), Tire Size Correction (For acceleration and timing accuracy.), and Vehicle weight input. </p><p></p><p>Option INCLUDES the revolutionary A'PEX G-Sensor. The G Sensor allows the unit to measure G forces in 4-way front/rear/left/right directions. This data can be plotted in a graph display to map acceleration characteristics and lateral G's on the race track, or used in an array of new features including: Highly accurate 100m/200m/400m times with trap speed and wheel-spin correction, Horse Power Calculation, and Loss Power Calculation. By taking advantage of the optional G Sensor, the user can produce extremely accurate power measurements. Usually, when measuring 0-400m times through the speed sensor signal alone, the meter will end measurement too early (shorter distance) due to wheel-spin. Using the G Sensor modifies the speed sensor signal, compensating for wheel-spin and producing impeccably accurate acceleration times.</p></blockquote><p></p>
[QUOTE="BobcatSysOp, post: 1103932, member: 22244"] Here is just some information on how RSM works and G-sensors do. (RSM) Rev/Speed Meter measures and monitors data such as vehicle speed, engine RPM, and elapsed times. The screen uses the easy to read VFD (Vacuum Fluorescent Display) with built in light sensor used in many of A'PEX's line up. Standard features include: Engine RPM, Vehicle Speed, Travel Distance, and Battery Voltage (All which can be displayed in real time graph mode, numerical mode, or analogue mode; 1-4 channels at a time.), Peak Hold, Replay (With 60 second playback.), Speed Limiter Cut, 0-100m/200m/400m times with trap speed, 0-100km/h/200km/h/300km/h times, Mid Range Acceleration (The user can preset any range of speed to measure.), Stop Watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM and Speed Outputs (For external devices requiring an RPM or speed signal like a shift light.), Tire Size Correction (For acceleration and timing accuracy.), and Vehicle weight input. Option INCLUDES the revolutionary A'PEX G-Sensor. The G Sensor allows the unit to measure G forces in 4-way front/rear/left/right directions. This data can be plotted in a graph display to map acceleration characteristics and lateral G's on the race track, or used in an array of new features including: Highly accurate 100m/200m/400m times with trap speed and wheel-spin correction, Horse Power Calculation, and Loss Power Calculation. By taking advantage of the optional G Sensor, the user can produce extremely accurate power measurements. Usually, when measuring 0-400m times through the speed sensor signal alone, the meter will end measurement too early (shorter distance) due to wheel-spin. Using the G Sensor modifies the speed sensor signal, compensating for wheel-spin and producing impeccably accurate acceleration times. [/QUOTE]
Renault Megane RS Trophy shatters its own ‘Ring record for FWD w/video
https://www.zerotohundred.com/wp-content/uploads/2011/06/renault-600x324.jpg
Up until recently, the fastest front-wheel drive (FWD) car to lap the famed Nurburgring was the hottest hatch of the moment, the Renault...
Today's Tour: Infiniti and Red Bull Racing at the Malaysian GP 2011
It's the season again. it is perhaps the most anticipated time of the year for us as there'll be tours from the manufacturers...
hks turbo for sale
want to sell hks GT PRO turbine complete hks acuator..
GT-2835
fit nicely to rb engine..
http://img2.freeimagehosting.net/uploads/b93b0a2ba6.jpg
Car Brands
Car Manufacturers
Honda
Rsm , Vafc
