Car Brands
Car Manufacturers
Honda
rocker arm.
<blockquote data-quote="J101" data-source="post: 2064148" data-attributes="member: 15660"><p>LMA = spring with a plate on top. if the tapping sounds speeds up as rpms speed up, and goes away when you hit vtec, and the vtec rocker doesnt come back up when you push it down (physically check with your fingers), then its the LMA. but then again, noise can be alot of things. check your valve clearance and also probably a worn out rocker arm that is hitting back and forth.</p><p></p><p>maybe you should know better since u said "i notice everytime after doin a b16 conversion".</p><p></p><p></p><p>godspeed</p></blockquote><p></p>
[QUOTE="J101, post: 2064148, member: 15660"] LMA = spring with a plate on top. if the tapping sounds speeds up as rpms speed up, and goes away when you hit vtec, and the vtec rocker doesnt come back up when you push it down (physically check with your fingers), then its the LMA. but then again, noise can be alot of things. check your valve clearance and also probably a worn out rocker arm that is hitting back and forth. maybe you should know better since u said "i notice everytime after doin a b16 conversion". godspeed [/QUOTE]
100 BMW 528i M Performance units for a bargain! - BMW 100th
The F10 BMW 528i has been refreshed for some time around March this year, with the addition of M Sport package and a price reduction from just over RM417,800 down to RM378,800 due to eligibility of EEV tax incentive...
safc 2 setting
Hello.....Bro,anybody know how to setting safc2 on my ride 4g93t...please help me.
Tuned By STi : Subaru Legacy Wagon and B4 Sedan
Subaru Technica International has released the STi package for the 2 models above. The "Tuned...
Car Brands
Car Manufacturers
Honda
rocker arm.
