Car Clubs
Car Club Categories
The Altezza / IS200 / IS300 Forum
Rim Clearance
<blockquote data-quote="1JZtezza" data-source="post: 3710467" data-attributes="member: 66560"><p>Not wanting to pour cold water -really</p><p></p><p>Front should be 225 tyre and depending on series and suspension set-up(lowered or non lowered) may just clear.</p><p>Rear minimum tyre size for 9jj is 235(i run a 245).You may have problems with the arches.</p><p></p><p>With this configuration and standard engine your consumption is gonna go up and you will lose top-speed.</p></blockquote><p></p>
[QUOTE="1JZtezza, post: 3710467, member: 66560"] Not wanting to pour cold water -really Front should be 225 tyre and depending on series and suspension set-up(lowered or non lowered) may just clear. Rear minimum tyre size for 9jj is 235(i run a 245).You may have problems with the arches. With this configuration and standard engine your consumption is gonna go up and you will lose top-speed. [/QUOTE]
GREDDY intake manifold for RB25det
i have used intake greddy for Rb25 in tip top condition !!
it's come with throttle body !!
i have 2 set of the intake greddy !!
1 set with original throttle body with greddy adapter !
1 set with 90mm nissan throttle...
Dave Rogers (initial D music author) in loves with MY EVO 7 :))
dis is the reason wat motorsports is called :))
http://youtube.com/watch?v=kACgOWFrbhs
the way the driver attacked the circuit is really CLIMAXING n STIM !!!!!!!!!!!!!!!
the enthusiastic crew pit n the...
Why EVO?????? MUST READ ALL MEMBERS
Hello all members of MLOC
i am sure we dun need to answer the question in terms of performance, the legendary history of evo and etc. wat i really want to voice out as a reason for owning evo is the great MLOC.
i...
Car Clubs
Car Club Categories
Rim Clearance
