Main Forums
Car Talk
Car Modification
Retarding CAM timing
<blockquote data-quote="flamefox850" data-source="post: 682808" data-attributes="member: 140"><p>yerp..u r correct dude. adjusting the cam pulley timing will adjust ignition timing also on SOHC engine as the distributor also attached to camshaft.</p><p></p><p>but....yeah the ecu have auto-advance and auto-retard feature. normally it will advance timing when sense less boost or got vacuum as 'it' dun want the engine die when idle and got more umpphh when using a little high gear on low rpm. and it will auto-retard when sensing more boost coming (if turbo)</p><p></p><p>that's why i only using bigger injectors and set -ve setting on my safc, my engine got horrible knock even though i never touch my distributor at that time. this is cause by the ecu sees less boost with the -ve setting at safc.</p><p></p><p>and yes, dyno tune, knock sensor tuning and wide band tuning is a must when u want more power and more safe ride. but for poor guy like me...what to do...adjust secukup rasa only la hehehe</p></blockquote><p></p>
[QUOTE="flamefox850, post: 682808, member: 140"] yerp..u r correct dude. adjusting the cam pulley timing will adjust ignition timing also on SOHC engine as the distributor also attached to camshaft. but....yeah the ecu have auto-advance and auto-retard feature. normally it will advance timing when sense less boost or got vacuum as 'it' dun want the engine die when idle and got more umpphh when using a little high gear on low rpm. and it will auto-retard when sensing more boost coming (if turbo) that's why i only using bigger injectors and set -ve setting on my safc, my engine got horrible knock even though i never touch my distributor at that time. this is cause by the ecu sees less boost with the -ve setting at safc. and yes, dyno tune, knock sensor tuning and wide band tuning is a must when u want more power and more safe ride. but for poor guy like me...what to do...adjust secukup rasa only la hehehe [/QUOTE]
R35 Used Titanium Exhaust
Launch Control?
Ever tried pressing the brake hard with left foot and at the same time, pinning your throttle to metal to build the rev and boost before taking off?
I want to know how 'serious' will the damage be on the gearbox?
make MR-S to be handful 4 track
Chassis Reinforcement for MR-S
spot welding & additional braces (body)
http://img120.imageshack.us/img120/93/nippy2121img600x4301161us7.jpg
http://img528.imageshack.us/img528/1543/nippy2121img600x4301161fz9.jpg...
halo-gtr-34
may i know y r-34 hv 4 step on leg?expect alceration ,braking and clutch & wats is the last?(sorry for poor english)
Main Forums
Car Talk
Car Modification
