Car Brands
Car Manufacturers
Proton
Removing Engine Cover!!!
<blockquote data-quote="yeehau86" data-source="post: 4359806" data-attributes="member: 48776"><p>I just follow step 2 and 7 only. using not those ordinary philips or flat screw drivers. Dunno how to explain in english, the screw driver is long type one. Like those the mechanic use to take out your spark plug that long.</p><p></p><p>http://img.photobucket.com/albums/v288/trimovingxr/Dsc00483.jpg</p><p></p><p>http://www.realoem.com/bmw/diagrams/c/k/6.png</p><p></p><p>this is the driver to open for my case:</p><p></p><p>http://static.letsbuyit.com/filer/images/uk/products/original/111/83/sealey-t-handle-nut-driver-9-x-300mm-11183727.jpeg</p><p></p><p>there are other shorter one, but most important is same "head"</p></blockquote><p></p>
[QUOTE="yeehau86, post: 4359806, member: 48776"] I just follow step 2 and 7 only. using not those ordinary philips or flat screw drivers. Dunno how to explain in english, the screw driver is long type one. Like those the mechanic use to take out your spark plug that long. http://img.photobucket.com/albums/v288/trimovingxr/Dsc00483.jpg http://www.realoem.com/bmw/diagrams/c/k/6.png this is the driver to open for my case: http://static.letsbuyit.com/filer/images/uk/products/original/111/83/sealey-t-handle-nut-driver-9-x-300mm-11183727.jpeg there are other shorter one, but most important is same "head" [/QUOTE]
R35 Used Titanium Exhaust
17inch rim
how much does it cost for new china,local n taiwan rims?just a price guide...
Afc neo doesnt have karman signal.
Hi all sifu,
i bought a second hand afc neo..
and i installed it in my evo 3 engine.
so i go to etc-->sensor check..i found out that my karman reading is --
nothing at all..isit normal?cause as i knw evo3 is using...
Emanage Blue for FD1
Would like to know if emanage blue compatible with FD1?
Any FD1 user installed emanage blue? If yes, any problem encountered?
Coz i would like to install one.
Car Brands
Car Manufacturers
Proton
