Main Forums
Car Talk
Car Modification
Remove Revcut - Discussion
<blockquote data-quote="aja" data-source="post: 4362431" data-attributes="member: 963"><p>To remove the rev cut for the standard ECU in order to make the car rev higher for normal NA car is pretty dangerous. if you really need to rev higher, better option is to buy those Variable Valve engine such as Vtec, Mivec etc..</p><p></p><p>However, it sesiapa really want to go for it, make sure the tuner Air + Fuel Ratio setting is correct so that the engine durability is there and do some research on the successful result. </p><p></p><p>Twelve years ago, Charlie of Matspeed did the ECU Rechip (by adding E-prom) to my Wira Aeroback 1.6M (4G92P SOHC). My conclusion about the result: The mid-power and top-end is better. Fourth gear redlined at 8000 rpm or so (sorry can't recall) at 200kmh. 5th gear proton is useless, therefore it's hardly go past 205 kmh. Everything else are stock (except for the rear muffler).</p><p></p><p>Charlie told me that before he commercialised the new setting for SOHC 4G92P, he took more that six months to test it's reliability. Then only he dare to commercialised it. </p><p></p><p>My suggestion is that please do your research before doing it or to get the correct tuner to do it.</p></blockquote><p></p>
[QUOTE="aja, post: 4362431, member: 963"] To remove the rev cut for the standard ECU in order to make the car rev higher for normal NA car is pretty dangerous. if you really need to rev higher, better option is to buy those Variable Valve engine such as Vtec, Mivec etc.. However, it sesiapa really want to go for it, make sure the tuner Air + Fuel Ratio setting is correct so that the engine durability is there and do some research on the successful result. Twelve years ago, Charlie of Matspeed did the ECU Rechip (by adding E-prom) to my Wira Aeroback 1.6M (4G92P SOHC). My conclusion about the result: The mid-power and top-end is better. Fourth gear redlined at 8000 rpm or so (sorry can't recall) at 200kmh. 5th gear proton is useless, therefore it's hardly go past 205 kmh. Everything else are stock (except for the rear muffler). Charlie told me that before he commercialised the new setting for SOHC 4G92P, he took more that six months to test it's reliability. Then only he dare to commercialised it. My suggestion is that please do your research before doing it or to get the correct tuner to do it. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Ministry of Sound and Nissan Partner To Create - The Juke Box!
If you didn’t already know, the Ministry of Sound (MOS) Group is a global youth...
Boss kit for Evo 7 8 9 with airbag aka GSR model
Hi there, anyone with experience in changing their Oem steering (with airbag) to those momo or sparcos? Where do you get the boss kit from in Malaysia. Any local alternative? Besides buying from Japan. Also. What...
Cleaning your throttle body
http://farm7.static.flickr.com/6022/5982995411_b5bdc8bee4.jpg
My last
DIY post on the oil catch...
Main Forums
Car Talk
Car Modification
