Main Forums
Car Talk
Car Modification
Relation between crank, conrod and piston
<blockquote data-quote="xtremeleo" data-source="post: 4498276" data-attributes="member: 18941"><p>vr4 complete bottom end is the fave for high hp application sir, bullet proof as they always call it</p></blockquote><p></p>
[QUOTE="xtremeleo, post: 4498276, member: 18941"] vr4 complete bottom end is the fave for high hp application sir, bullet proof as they always call it [/QUOTE]
david tao
Who can rebuild HKS T04R?
Hello turbo lovers,
I just bought a HKS T04R. This one is the journal bearing turbo, later T04Z became ball bearing.
So who do you know can rebuild this turbo?
Thanks
4G93T Problem when Boost Kick In
Hi all sifu, wanna get advice from you all, I have the following problem after I have upgrade my fuel pump to walbro.
boost kick in then until 4K rpm suddenly turbo lag for 1K rpm range then boost come in again...
sabah/sarawak AP vs local AP
what the different sabah/sarawak Ap compare to local Ap...? as i know sabah sarawak AP more cheaper n get loan from bank less than local Ap!!!
Main Forums
Car Talk
Car Modification
