Main Forums
Car Talk
Forced Induction & Engine Management
regarding about my boost meter
<blockquote data-quote="SYeNi69" data-source="post: 4132874" data-attributes="member: 32651"><p>I'm no Sifu but this is sumthing ive learned while playing with turbo 's .. just to share ... </p><p></p><p>In that case ...</p><p></p><p>1. Boost pressure leak ... maybe ur pipes or BOV ...</p><p>2. Ur actuator/actuator spoilt cause ur not getting stable readings ... </p><p></p><p>for ex. </p><p></p><p>if u are using wastegate and ur spring rate is 0.7bar spring ... there is now way u would get a reading of 0.7 and below if everything is going well :wavey: ... theres no way for u to reduce the boost unless u change the spring ...</p><p></p><p>if u are using actuator and boost is set at a minimum of 0.7 ... same thing ... unless the actuator has been altered ... or spoilt ...</p><p></p><p>how to check for leaks if BOV </p><p>- simple way ... replace the BOV and try and put battery or sumthing at the BOV hos or pipes ... if boost go up and stable .. it means ur BOV bocor ... if not ... try the ones below ...</p><p></p><p>How to check if ur actuator or wastegate prob ...</p><p>- simple way ... disconnect the vacuum line going into actuator or wastegate and shut it with a skru or anything that can fit in the small hose ... if boost go up like mad ... it means its working ... but then if ur boost meter showing that its still stuck at 0.5-0.7 even at WOT ... go get it replaced ... try this and be gentle with ur FOOT !!</p><p></p><p>How to check if got leaks ... </p><p>- get two boost meters ... the vacuum hoses - one tapped at the turbo housing or sumwhere near the turbo (b4 any hoses and intercooler) and the other at ur intake manifold ... if there is a difference in reading then got leaks ... </p><p></p><p>the one at the turbo is showing the correct amount of boost ... The one at the intake manifold is the amount going into the engine ... there shouldnt be a difference ... if different check ur pipes :wavey: </p><p></p><p>this is some of the reasons ... heck there are alot of other reasons but then these are the basics ... <img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/biggrin.gif" class="smilie" loading="lazy" alt=":biggrin:" title="Biggrin :biggrin:" data-shortname=":biggrin:" /></p><p></p><p>HAPPY BOOSTING <img src="https://zerotohundred.com/forums/styles/default/xenforo/smilies/nurse.gif" class="smilie" loading="lazy" alt=":nurse:" title="Nurse :nurse:" data-shortname=":nurse:" /></p></blockquote><p></p>
[QUOTE="SYeNi69, post: 4132874, member: 32651"] I'm no Sifu but this is sumthing ive learned while playing with turbo 's .. just to share ... In that case ... 1. Boost pressure leak ... maybe ur pipes or BOV ... 2. Ur actuator/actuator spoilt cause ur not getting stable readings ... for ex. if u are using wastegate and ur spring rate is 0.7bar spring ... there is now way u would get a reading of 0.7 and below if everything is going well :wavey: ... theres no way for u to reduce the boost unless u change the spring ... if u are using actuator and boost is set at a minimum of 0.7 ... same thing ... unless the actuator has been altered ... or spoilt ... how to check for leaks if BOV - simple way ... replace the BOV and try and put battery or sumthing at the BOV hos or pipes ... if boost go up and stable .. it means ur BOV bocor ... if not ... try the ones below ... How to check if ur actuator or wastegate prob ... - simple way ... disconnect the vacuum line going into actuator or wastegate and shut it with a skru or anything that can fit in the small hose ... if boost go up like mad ... it means its working ... but then if ur boost meter showing that its still stuck at 0.5-0.7 even at WOT ... go get it replaced ... try this and be gentle with ur FOOT !! How to check if got leaks ... - get two boost meters ... the vacuum hoses - one tapped at the turbo housing or sumwhere near the turbo (b4 any hoses and intercooler) and the other at ur intake manifold ... if there is a difference in reading then got leaks ... the one at the turbo is showing the correct amount of boost ... The one at the intake manifold is the amount going into the engine ... there shouldnt be a difference ... if different check ur pipes :wavey: this is some of the reasons ... heck there are alot of other reasons but then these are the basics ... :biggrin: HAPPY BOOSTING :nurse: [/QUOTE]
Toyota Prius c Hybrid Campaign
With Hari Raya...
Simplified guide to Engine Oils
http://farm7.static.flickr.com/6023/6021285628_4951a94a1f.jpg
Yes... Hello Kitty really is taking over the world.
I posted a...
Did anyone resolve the sticky airbag cover issue?
Hey guys,
My dashboard beginning to rot but I can live with it for another 1 plus yr. The sticky passenger airbag cover is really bugging me now. Any DIY solutions guys?
Main Forums
Car Talk
