Main Forums
Interests
ICE
Recommendation on SUB + AMP
<blockquote data-quote="Izso" data-source="post: 857385" data-attributes="member: 2429"><p>no need to power the rear comps la.. but it's totally up to you since it's your ears that you need to appease.. not mine. :D </p><p></p><p>What sub amp you settled on? Are you interested in a Alpine V12 Monoblock M501 selling for RM1k? 550 watts at 2ohms 12volts!</p></blockquote><p></p>
[QUOTE="Izso, post: 857385, member: 2429"] no need to power the rear comps la.. but it's totally up to you since it's your ears that you need to appease.. not mine. :D What sub amp you settled on? Are you interested in a Alpine V12 Monoblock M501 selling for RM1k? 550 watts at 2ohms 12volts! [/QUOTE]
Radiator Fan
Hi SIfu,
i plan to change my Radiator Fan. so ask all sifu, normally is change Original or OEM (High Speed Fan) ?
Cabin light dimmer
Guys, anyone tried doing a light dimmer in your cabin? Like those BMW when the door closed, the cabin light will only goes off after a few seconds...
WEBER or INJECTION ?
I have been considering to upgrade my air intake. I know export models of Saga uses ECU. How do I get that?
And I been wondering how WEBER will do on Saga engine oso.
Im using 1.3cc Iswara.....
Any sifu here to...
Main Forums
Interests
ICE
