Main Forums
Car Talk
Car Modification
rear drum 2 rear disc
<blockquote data-quote="vestax" data-source="post: 306759" data-attributes="member: 41"><p>i don't see why you can't use the rear disc brakes , anyway the rear won't be greater then the front , if you had purchase the correct brake set . make sure the rear brake caliper piston is smaller then the front , then u`ll be fine with it . logically speaking , front has shorter travel distance then the rear , cause the fluids need to travel to pressure the caliper pistons , so the front brakes will have great response then the rear due to the short brake line , and when doing hard braking , the front will always lock first rather then the rear . if your rear locks and the front doesn't then its not a good sign , cause you`ll fish tail and lose control under hard braking .</p></blockquote><p></p>
[QUOTE="vestax, post: 306759, member: 41"] i don't see why you can't use the rear disc brakes , anyway the rear won't be greater then the front , if you had purchase the correct brake set . make sure the rear brake caliper piston is smaller then the front , then u`ll be fine with it . logically speaking , front has shorter travel distance then the rear , cause the fluids need to travel to pressure the caliper pistons , so the front brakes will have great response then the rear due to the short brake line , and when doing hard braking , the front will always lock first rather then the rear . if your rear locks and the front doesn't then its not a good sign , cause you`ll fish tail and lose control under hard braking . [/QUOTE]
david tao
custom stering boss kit..
i am looking for a short stering hub for my kancil but carn find 1. so i was thinking to custom do my own short hub. i am doing this cause i am using the deep dics stering, omp type. can any 1 share where can i go to...
wtb: Lancer MX original back seat
my friends converted 6.5 in red colour, kena break in, all seat and all meter been stoled, now he looking for Lancer MX back seat only
anyone have pls contact me @ 012-3867819.
thanks
guys.. what is the logo for ZTH????
hey guys.. wat is the logo of zth??? anyway can we use it on our car???
Main Forums
Car Talk
Car Modification
