Car Brands
Car Manufacturers
Honda
Rear Disc Brake Querries
<blockquote data-quote="shiroitenshi" data-source="post: 1435947" data-attributes="member: 27518"><p>Compared to stock.. betterlah! Anyway, I think you're right about the pads improving braking power.. but as for the discs.. erm.. I don't think solah about increasing power... unless the project u discs are bigger. I do know they are lighter than the stock EK9 discs for less rotational drag.. but seriously.. I've hardly ever fully stepped on the brake, since its stopping power is great for the weight of the EG.</p><p></p><p>Anyway..for dragsters, less-weight is king.. If got two lugs, they will use that! ROFL! if no need brakes, even better! Bigger disc = weight!</p><p></p><p>For everyday use, 5 lug is better .. somemore, can use with new civic 2006 rims, I think (not sure if the offset is the same). I think the new hondas all will start using 5 lugs already... so aftermarket wise, might see 5 lugs becoming more common.</p></blockquote><p></p>
[QUOTE="shiroitenshi, post: 1435947, member: 27518"] Compared to stock.. betterlah! Anyway, I think you're right about the pads improving braking power.. but as for the discs.. erm.. I don't think solah about increasing power... unless the project u discs are bigger. I do know they are lighter than the stock EK9 discs for less rotational drag.. but seriously.. I've hardly ever fully stepped on the brake, since its stopping power is great for the weight of the EG. Anyway..for dragsters, less-weight is king.. If got two lugs, they will use that! ROFL! if no need brakes, even better! Bigger disc = weight! For everyday use, 5 lug is better .. somemore, can use with new civic 2006 rims, I think (not sure if the offset is the same). I think the new hondas all will start using 5 lugs already... so aftermarket wise, might see 5 lugs becoming more common. [/QUOTE]
david tao
hard to shift to 2nd gear
Hi guys, my e9 when i shift from 1st gear to 2nd gear i have to push harder to get the gear in, and its not smooth like other gear,someting like krik krok then gear in, and only hapend to 2nd gear,other gear no...
2008 Toyota New AE86
The rumors were right, Toyota has resurrected the iconic AE86 from the 80s, the new drift legend...
MINI Clubman-The Xtended MINI
What have they done to the Mini? This is the new Mini Clubman.
As this photo shows, the Mini Clubman will have van-style...
Car Brands
Car Manufacturers
Honda
