Main Forums
Car Talk
Radiator water?
<blockquote data-quote="netmatrix" data-source="post: 964371" data-attributes="member: 217"><p>Damn how many times have we discussed this anyway? I think since mid last year till now. Does anyone bother to use the search function in ZTH or even bother to use Google? Aiyahhhh!!!!!:rolleyes: </p><p></p><p>I tell you guys come things only a few people know from here la, since the loooonggggg way back in ancient ZTH time ago.<img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1444" alt=":wink:" title="Wink :wink:" loading="lazy" data-shortname=":wink:" /> </p><p></p><p>Coolant is also <span style="color: red">LUBRICANT.</span></p><p>Faulty <span style="color: red">RADIATOR CAPS</span> also contribute to radiator failure. If ths spring doesn;t work nicely or badly rusted or the rubber is worn or crack, then change it! Blardy hell RM20 cap cannot afford to change. Those who spend RM200 on radiator caps can skip this. I have got nothing to say to them.</p><p></p><p>Radiator hose. Squeeze the bugger. If there is cracking sound inside, change the <span style="color: red">HOSE</span>! Those who use silicone based hose can ignore this.</p><p></p><p>Coolant, no matter how expensive is not magic. Even an ordinary Denso RM20 coolant is very good liao. All not higher priced than water wetter whatever. I could probably buy 3 bottles of Toyota coolant and change the water 6 months apart than spend so much on coolant additive. But different people different ideology. For me its just economic sense.</p></blockquote><p></p>
[QUOTE="netmatrix, post: 964371, member: 217"] Damn how many times have we discussed this anyway? I think since mid last year till now. Does anyone bother to use the search function in ZTH or even bother to use Google? Aiyahhhh!!!!!:rolleyes: I tell you guys come things only a few people know from here la, since the loooonggggg way back in ancient ZTH time ago.:wink: Coolant is also [color=red]LUBRICANT.[/color] Faulty [color=red]RADIATOR CAPS[/color] also contribute to radiator failure. If ths spring doesn;t work nicely or badly rusted or the rubber is worn or crack, then change it! Blardy hell RM20 cap cannot afford to change. Those who spend RM200 on radiator caps can skip this. I have got nothing to say to them. Radiator hose. Squeeze the bugger. If there is cracking sound inside, change the [color=red]HOSE[/color]! Those who use silicone based hose can ignore this. Coolant, no matter how expensive is not magic. Even an ordinary Denso RM20 coolant is very good liao. All not higher priced than water wetter whatever. I could probably buy 3 bottles of Toyota coolant and change the water 6 months apart than spend so much on coolant additive. But different people different ideology. For me its just economic sense. [/QUOTE]
Advan GT Beyond 19 Civic Type R FK8 FL5 Rim Wheel
TE37 Saga S Plus 18 Civic Type R FL5 FK8
jeff6126
Honda Jazz FLRS side skirt
jeff6126
yellowcaliper /caliperspray
jeff6126
Te37 Track Edition 2 FK8 FL8 Civic Type R Rim Wheel...
Revozport R35 GT Wing Spoiler and Trunk
original rare Work Emotion 11R 18x8.5jj offset +47...
david tao
Spoon FK8 FL5 19 inch rim wheel Type R
Litchfield GTR R35 Road Suspension Kit Absorber
Emanage Blue help
guys..
using emanage blue on mazda BPT 1.8 pressure reading from 3bar map by V
my problem is why WOT ( wide open throttle ) detect only 30%.?
previously done tuning but after overhauling my engine and still remain...
About Lancer Cedia 1.5 GDI...
Anybody know about tis car? got any information for tis car?
tis car spare part / aftermarket part is hard to find?
if bought tis car what i to need to pay attention?
newbie....
As it seems, there has been a need for another technical discussion on tuning theory. I think more and more questions arise why you run 12:1 afr vs. 13:1 or 14:1 or this certain ignition timing. Anyone can just find...
Main Forums
Car Talk
Radiator water?
