Main Forums
Car Talk
Radiator help!!
<blockquote data-quote="sache" data-source="post: 1798640" data-attributes="member: 42037"><p>Yeah, try crazykid opinion/recommendations, it will helps. Coz sometimes when you dont service or replace the water in the radiator, the water pump got stain and it cant move or move slowly which not help reduce the temp.</p><p>You also should start using coolant which help reduce time of getting stain for the water pump and the part of the radiator. Please make sure you monitor the process of replacement and cleaning your radiator in case they "will cheat" on you.</p></blockquote><p></p>
[QUOTE="sache, post: 1798640, member: 42037"] Yeah, try crazykid opinion/recommendations, it will helps. Coz sometimes when you dont service or replace the water in the radiator, the water pump got stain and it cant move or move slowly which not help reduce the temp. You also should start using coolant which help reduce time of getting stain for the water pump and the part of the radiator. Please make sure you monitor the process of replacement and cleaning your radiator in case they "will cheat" on you. [/QUOTE]
R35 Used Titanium Exhaust
Wifi enabled car
Just wanna share my new and low cost diy..
Bought this mini portable 3g/4g wifi router and plan to fix permanently inside my cockpit...
Saab puts out a promotional video of the upcoming Mille Miglia 2011
https://www.zerotohundred.com/wp-content/uploads/2011/05/millemiglia.jpg
Saab does a promotional video of the upcoming Mille Miglia 2011 Rally, a transnational car rally for cars manufactured before 1957. Cars will...
Transmission and transfer case oil
Hi
How much for original Mitsubishi transmission and transfer case oil?where can i buy it. thanks
Main Forums
Car Talk
Radiator help!!
