Main Forums
Car Talk
Car Modification
Questions bout turbo
<blockquote data-quote="Zeroed" data-source="post: 891916" data-attributes="member: 98"><p>Heheh I know, I was just saying that it wont necessarily be more expensive. You can do the same thing on 4G92s or some other engines also anyway. :D And Im pretty sure they wouldnt need years on research to make a turbo variant of the same engine... Im not developing my own engine as well, technically Im using the parts they developed so its not quite a mechanic's experimental play toy. ;)</p><p></p><p>I've also done my research... What I gather from reputable mechanics is the engine block internals of a 93P and 93T are no different other than the pistons and the additional oil squirter, with a piston conversion things should hold up pretty well.</p><p>And you say things may go wrong... but what is there to go wrong with everything done properly? This is atleast, for my case la.</p><p></p><p>Dropping in an unknown used engine which came in a container exposed to the seas is IMO equally as risky...</p><p></p><p>return cheers ;)</p></blockquote><p></p>
[QUOTE="Zeroed, post: 891916, member: 98"] Heheh I know, I was just saying that it wont necessarily be more expensive. You can do the same thing on 4G92s or some other engines also anyway. :D And Im pretty sure they wouldnt need years on research to make a turbo variant of the same engine... Im not developing my own engine as well, technically Im using the parts they developed so its not quite a mechanic's experimental play toy. ;) I've also done my research... What I gather from reputable mechanics is the engine block internals of a 93P and 93T are no different other than the pistons and the additional oil squirter, with a piston conversion things should hold up pretty well. And you say things may go wrong... but what is there to go wrong with everything done properly? This is atleast, for my case la. Dropping in an unknown used engine which came in a container exposed to the seas is IMO equally as risky... return cheers ;) [/QUOTE]
david tao
Bonfi turbo asia sdn. Bhd.
Bro,
Anybody heard bout Bonfi turbo asia????? Recently i feel that Turbocharger for my Ford ranger sometime working and sometime not....so now i think its time for me to do the survey.
i heard bonfi turbo asia...
Spy shots: Hyundai RWD Coupe
Computer-generated image of the RWD Coupe.
Don't dismiss Hyundai as "just another Korean car maker", the Korean company is rolling out its new RWD BH-platform on which the new Coupe will...
pros and cons of lightweight flywheel and racing clutch??
anyone here can tell the
pros
and
cons
of
and
racing clutch
Main Forums
Car Talk
Car Modification
