Main Forums
Car Talk
Putra setting
<blockquote data-quote="whatdamn" data-source="post: 1424101" data-attributes="member: 5381"><p>normally for wira/putra/satria, a good starting point would be to get 5 kg front and 3 kg rear. which i have been told is the max you should go unless you get a roll cage. because apparently you're only gonna appriciate the stiffer setup from reduce flexing of the chassis due to the roll cage.</p><p></p><p>good point to check before blamming it on springs/dampers, anti roll bars. to stiff and you might lift the inner will when taking a turn.</p></blockquote><p></p>
[QUOTE="whatdamn, post: 1424101, member: 5381"] normally for wira/putra/satria, a good starting point would be to get 5 kg front and 3 kg rear. which i have been told is the max you should go unless you get a roll cage. because apparently you're only gonna appriciate the stiffer setup from reduce flexing of the chassis due to the roll cage. good point to check before blamming it on springs/dampers, anti roll bars. to stiff and you might lift the inner will when taking a turn. [/QUOTE]
R35 Used Titanium Exhaust
Airtrek Turbo Ralliart Muffler
Guys, anyone has this for sale?
Thanks.
Renault Megane RS Trophy shatters its own ‘Ring record for FWD w/video
https://www.zerotohundred.com/wp-content/uploads/2011/06/renault-600x324.jpg
Up until recently, the fastest front-wheel drive (FWD) car to lap the famed Nurburgring was the hottest hatch of the moment, the Renault...
Nissan FORUM Concept : The "Mobile" Lounge
The Forum’s unique ‘turntable’ seating streaked across the web last week, as did news of its built-in microwave oven and extensive...
Main Forums
Car Talk
Putra setting
