Main Forums
Car Talk
Proton Saga Magma Engine Knocking
<blockquote data-quote="RigerZ" data-source="post: 1064634765" data-attributes="member: 141222"><p>I've been having engine knocking after sending the car for servicing (changed timing belt and all the V-belts).</p><p></p><p>Retarded the timing to maximum worked for a while but eventually the knocking came back.</p><p>It tends to knock more when the aircond is on and/or going up a slope.</p><p>Mainly happens at 1500-2000rpm on gentle acceleration.</p><p>Noticed it knocks more during evening drive back from work, almost never knocks in the early morning.</p><p></p><p>Havent changed spark plugs and been using the same petrol all the while.</p><p></p><p>I suspect the workshop messed with the carburettor because I also noticed my idle speed is higher now (around 1000rpm) compared to before the service (700-800-850rpm). </p><p></p><p>What do you guys think?</p></blockquote><p></p>
[QUOTE="RigerZ, post: 1064634765, member: 141222"] I've been having engine knocking after sending the car for servicing (changed timing belt and all the V-belts). Retarded the timing to maximum worked for a while but eventually the knocking came back. It tends to knock more when the aircond is on and/or going up a slope. Mainly happens at 1500-2000rpm on gentle acceleration. Noticed it knocks more during evening drive back from work, almost never knocks in the early morning. Havent changed spark plugs and been using the same petrol all the while. I suspect the workshop messed with the carburettor because I also noticed my idle speed is higher now (around 1000rpm) compared to before the service (700-800-850rpm). What do you guys think? [/QUOTE]
david tao
Toyo T1R vs Goodyear Eagle F1 Directional 5
Im planning to change my tire very soon. Im just too confused to pick which one of it. T1R or Directional 5?
Help me please.. Thanks!
Engine balancing in JB?
Anyone knows anywhere that can do engine balancing in JB? Only the balancing, not engine assembly.
How to fix superlon
Problems fixing superlon
Got SA 6mm, got it to fix on wira door panels.
Superlon seems to thick for the car door panel, cant close properly.
Anyone can help?
Main Forums
Car Talk
