Hey guys,
anyone know the proper way to check atf fluid ?
i change atf fluid jus now, but not sure the level is correct or not.
Fully drain the atf and pour in 4 bottle of atf oil as suggested.
I found a service manual for atf-xp3 but not sure for which model and i follow the instruction as below:
Warm up the engine and keep the engine running,
Pull handbrake and from P gear position, stop a while in every gear position until Level 2 and stop a while in every gear to neutral position back.
After that check the fluid level, the fluid level as picture below:
Black arrow: current fluid level
Blue arrow: The fluid level suppose to be here right when the engine is fully warm up and hot.
http://i537.photobucket.com/albums/ff337/walawei/ca566024-c7d5-42b4-8a39-270472c37a2f_zps1810941b.jpg
http://i537.photobucket.com/albums/ff337/walawei/Untitled-14_zps9043f487.png
