Car Clubs
Car Club Categories
The Cefiro Club Malaysia
Proper way to flush engine coolant
<blockquote data-quote="a31gtst" data-source="post: 1741103" data-attributes="member: 3086"><p>You must bleed out the air trapped in the coolant system after a flush. Otherwise there will be air bubbles trapped in the coolant system and this can cause an array of problems. I'm not sure about a32 but for a31 you can find the bleed nut quite easily, it should'nt be that hard to find for the a32 somewhere on top of the intake manifold you should be able to see a nut with a sticker that says do not open when hot.</p><p></p><p>A tell tale sign when you have air trapped in the cooling system is when you start hearing boiling or bubling sounds from your engine....they usually call it gastric!</p><p>Am not sure why your mech is scared of damaging water pump, a flush isnt that drastic....maybe you could try another workshop that handles alot of Nissans or a32 specifically. I'm sure the rest of the forumers will be able to help recommending.</p><p></p><p>Cheers</p></blockquote><p></p>
[QUOTE="a31gtst, post: 1741103, member: 3086"] You must bleed out the air trapped in the coolant system after a flush. Otherwise there will be air bubbles trapped in the coolant system and this can cause an array of problems. I'm not sure about a32 but for a31 you can find the bleed nut quite easily, it should'nt be that hard to find for the a32 somewhere on top of the intake manifold you should be able to see a nut with a sticker that says do not open when hot. A tell tale sign when you have air trapped in the cooling system is when you start hearing boiling or bubling sounds from your engine....they usually call it gastric! Am not sure why your mech is scared of damaging water pump, a flush isnt that drastic....maybe you could try another workshop that handles alot of Nissans or a32 specifically. I'm sure the rest of the forumers will be able to help recommending. Cheers [/QUOTE]
M3 GTS and SG Supercars at Traders Hotel KL
These are some pics of SG exotics at Trader's Hotel KL after their Track day at Sepang, mostly clients of Ascendant...
need advice
:hmmmm:
i wanna use gt35
prob is..which one is better..
- wastegate, tial 44mm or turbosmart 50mm???
- BOV, tial or Greddy type-RS or turbosmart
target HP +500-550
:hmmmm:
pening...
WTB: S14 SR20DE halcut
Looking to buy an S14 SR20DE halfcut +prop shaft + rear complete cradle. Please PM me.
Car Clubs
Car Club Categories
