Main Forums
Car Talk
Forced Induction & Engine Management
Problem with e-manage in WAJA
<blockquote data-quote="cipan_supercas" data-source="post: 2248242" data-attributes="member: 1945"><p>There are several reasons to why the ignition coil can fail when using e-manage. </p><p></p><p>1. Jumper setup:</p><p>JP1 should be configured as 2-3 to initiate a pull up voltage configuration. </p><p>So, when the engine is not started, only switched 'ON', the transistors inside the ignitor will remain in 'OFF' condition thus not waking up the coil that prevent burn out.</p><p></p><p>JP2 should be configured as 1-2 to initiate a 5 volt pull up condition. This is usually the voltage use by mitsu's ignition system to jerk the ignitor.</p><p></p><p>You can confirm this in the software when the e-manage got connected. You can also use an oscilloscope to confirm the activity of the coil.</p><p></p><p></p><p>Ahren wrote:</p><p>"I had consulted my foreman. He said WAJA and evo 4,5,6 which using e-manage will have this problem too. He said there is a electronic device that i must use together with the e-manage. But he is not quite sure what is that. anyone of you know what is that?"</p><p></p><p></p><p>I don't think you need to add any additional extra hardware to e-manage for that ignition problem. Mostly are from incorrect setup and wrong firmware. Please have your e-manage connected by a knowledgable installer. If he's just a trial an error installer, you'll face more problem than you expected.</p></blockquote><p></p>
[QUOTE="cipan_supercas, post: 2248242, member: 1945"] There are several reasons to why the ignition coil can fail when using e-manage. 1. Jumper setup: JP1 should be configured as 2-3 to initiate a pull up voltage configuration. So, when the engine is not started, only switched 'ON', the transistors inside the ignitor will remain in 'OFF' condition thus not waking up the coil that prevent burn out. JP2 should be configured as 1-2 to initiate a 5 volt pull up condition. This is usually the voltage use by mitsu's ignition system to jerk the ignitor. You can confirm this in the software when the e-manage got connected. You can also use an oscilloscope to confirm the activity of the coil. Ahren wrote: "I had consulted my foreman. He said WAJA and evo 4,5,6 which using e-manage will have this problem too. He said there is a electronic device that i must use together with the e-manage. But he is not quite sure what is that. anyone of you know what is that?" I don't think you need to add any additional extra hardware to e-manage for that ignition problem. Mostly are from incorrect setup and wrong firmware. Please have your e-manage connected by a knowledgable installer. If he's just a trial an error installer, you'll face more problem than you expected. [/QUOTE]
fs: Chargespeed fender rm 450
item not for sale anymore.
cheapskate owner chicken out
DIY Caliper Painting
As chnace would have it, i'm painting my calipers before they're installed. This is going to take approximately 1 week so be patient.
Tools
Dremmel with Wire Brush attachment
Polishing Bit
So after some time...
Symptoms of burnt spark plugs
Does anyone know what are the symptoms of a burnt spark plug? Is is similar to burnt cables? eg. car lethargic and misfiring
Reason for asking is because suddenly the car started to become very lethargic and when I...
Main Forums
Car Talk
