Car Brands
Car Manufacturers
Daihatsu
problem of G200 using G100 ABS
<blockquote data-quote="Devil_07" data-source="post: 2193563" data-attributes="member: 47644"><p><strong>abs</strong></p><p></p><p></p><p></p><p></p><p>I m not sure, I just changed the new abs last month, I saw have a mark G100 on the old abs..</p><p></p><p>My problem is my g202's rear site is lower then front site, is this spring problem? </p><p>But I have tried new spring also, but it still same.......</p><p></p><p>Pls help....</p></blockquote><p></p>
[QUOTE="Devil_07, post: 2193563, member: 47644"] [b]abs[/b] I m not sure, I just changed the new abs last month, I saw have a mark G100 on the old abs.. My problem is my g202's rear site is lower then front site, is this spring problem? But I have tried new spring also, but it still same....... Pls help.... [/QUOTE]
david tao
auto oil cooler
wanna know is it necessary for altezza to add on a automatic gear box oil cooler?
tq..
Most powerful Lotus Ever. The Evora GTE
Looks like Lotus has finally taken the step from building lightweight cars with very little power to the now brutally...
HELP:Emanage blue error code
my situation like this:-
i bought used emanage.i not yet wiring into my car.i try put power only and other wire not wiring at the emanage and try download map at home using desktop.1st time connection all ok...try...
Car Brands
Car Manufacturers
Daihatsu
